[QGIS-it-user] Qgis3 - KyngChaos
Tony75 iperstatica a gmail.com
Lun 12 Mar 2018 09:06:12 PDT
Salve
Ieri sera come da  post precedente
<http://osgeo-org.1560.x6.nabble.com/QGIS-3-beta-Installazione-su-macOS-tt5356513.html>
ho tentato vanamente di installare Qgis 3 eseguendo il porting con  macports
<https://www.macports.org>  . Questa mattina è stato inserita su KynChaos il
primo dgm della versione di Qgis3.0.1 per OSX.
Ho installato, ma quando avvio il programma  appare  schermata di errore e
un riquadro in cui sono appunto segnalati gli errori. Sapreste darmi qualche
info in merito? potrebbe essere causato dal porting?
Grazie
<http://osgeo-org.1560.x6.nabble.com/file/t382845/Schermata_2018-03-12_alle_16.png>
*Tutto il contenuto del riquadro è :*
Impossibile caricare il plugin 'processing'
ModuleNotFoundError: No module named 'osgeo'
  File "/Applications/QGIS
3.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 311, in
loadPlugin
    __import__(packageName)
3.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 664, in
_import
    mod = _builtin_import(name, globals, locals, fromlist, level)
3.app/Contents/MacOS/../Resources/python/plugins/processing/__init__.py",
line 28, in
    from processing.tools.dataobjects import *          # NOQA
_import
3.app/Contents/MacOS/../Resources/python/plugins/processing/tools/dataobjects.py",
line 51, in
    from processing.algs.gdal.GdalUtils import GdalUtils
_import
3.app/Contents/MacOS/../Resources/python/plugins/processing/algs/gdal/GdalUtils.py",
line 35, in
    from osgeo import gdal
_import
Versione Python: 3.6.4 (v3.6.4:d48ecebad5, Dec 18 2017, 21:07:28) [GCC 4.2.1
(Apple Inc. build 5666) (dot 3)]
Versione di QGIS: 3.0.0-Girona Girona, exported
Percorso Python:
/Applications/QGIS 3.app/Contents/MacOS/../Resources/python
/Users/Harlock/Library/Application
Support/QGIS/QGIS3/profiles/default/python
Support/QGIS/QGIS3/profiles/default/python/plugins
/Applications/QGIS 3.app/Contents/MacOS/../Resources/python/plugins
/Library/Frameworks/Python.framework/Versions/3.6/lib/python36.zip
/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6
/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/lib-dynload
/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Italian-User-f5250612.html
Maggiori informazioni sulla lista QGIS-it-user
