[QGIS-it-user] Qgis3 - KyngChaos
Tony75 iperstatica a gmail.com
Lun 12 Mar 2018 10:39:11 PDT
credo anche io che siano le librerie
ecco il risultato dalla console
import.sys
  File
"/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/code.py",
line 64, in runsource
    code = self.compile(source, filename, symbol)
  File
"/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/codeop.py",
line 168, in __call__
    return _maybe_compile(self.compiler, source, filename, symbol)
  File
line 99, in _maybe_compile
    raise err1
  File
line 87, in _maybe_compile
    code1 = compiler(source + "\n", filename, symbol)
  File
line 133, in __call__
    codeob = compile(source, filename, symbol, self.flags, 1)
  File "<input>", line 1
    import.sys
SyntaxError: invalid syntax
sys.path
  File
line 91, in runcode
    exec(code, self.locals)
  File "<input>", line 1, in <module>
NameError: name 'sys' is not defined
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Italian-User-f5250612.html
Maggiori informazioni sulla lista QGIS-it-user
