[Fwd: Re: [Fwd: Re: [Qgis-psc] [Fwd: Re: [Qgis-developer] oracle raster plugin]]]
Marco Hugentobler marco.hugentobler at karto.baug.ethz.ch
Tue Apr 14 23:43:05 PDT 2009
Hi
I had a quick look at the patch this morning.
The patch seems ok to me and if there are no further objections, I'm going to
apply it to trunk.
However, in the longer term it would probably be good to have a unified loading
dialog for rasters where file based and database GDAL datasources can be
selected (similar to the vector ogr loading dialog). Tim, what is your opinion
about this?
Regards,
Marco
Am Dienstag 14 April 2009 19:05:04 schrieb Paolo Cavallini:
> Hi all.
> I'm forwarding the patch, but I also suggested Ivan to send it to the
> -dev ML.
> All the best.
> -------- Messaggio Originale  --------
> Oggetto: Re: [Fwd: Re: [Qgis-psc] [Fwd: Re: [Qgis-developer] oracle
> raster plugin]]
> Data: Tue, 14 Apr 2009 07:09:11 -0400
> Da: Ivan Lucena <ivan.lucena at pmldnet.com>
> >> I am using the plugin all the time now because it helped me to find a
> >> bug in GDAL when loading a raster with pyramids. So right now I am
> >> working on my code in GDAL/GeoRaster and I will send the patch after
> >> that.
> > You can submit a bugfix later, but it's important that it goes in before
> > feature freeze.
> The bug that I am working on is on GDAL GeoRaster driver source code.
> The plugin itself is working fine.
> >> Thanks a lot,
> > Thanks to you, rather!
> There is PNG icon that is not included on the diff file and I don't know
> how I would send it other
> than by a attachment on a e-mail.
> My best regards,
> Ivan
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
Technical Advisor QGIS Project Steering Committee
More information about the Qgis-psc mailing list
