[Qgis-psc] bugfix donation
Paolo Cavallini cavallini at faunalia.it
Sun Apr 17 10:07:26 PDT 2011
Il giorno sab, 16/04/2011 alle 17.29 +0200, Paolo Cavallini ha scritto:
> We just received 740,00 EUR from Ramon Andinach, specifically targeted
> towards aspecific bugfixing. Our (me+tim) suggestion is to use these
> resources to put a bounty on bugs: every developer who wants self-assign
> a bug (to avoid two people working on the same ticket), then fixes it,
> and claims the money. We could start with a 50 € bounty (in fact the
> only amount that will round up is 37, but it may be too little), to fix
> the simple bugs and clean the queue, then moving to higher amounts if
> money will allow (other people are expected to join your effort), so to
> fix also more complex issues.
After the lengthy and a bit embarrassed discussion about this at the HF,
let's put down the alternatives:
* leave the money for the project
- pros: no discussion, everything keeps on working as it is
- cons: the donor will not have the impression of doing something
directly useful
* keep the original proposal: 25-50 € per bug
- should this be open for every developer, or just for committers, or
for outsiders only? There seem to be good reasons for each of the
options.
- should we have a first run at 25 € (10 bugs), so to clean the really
easy stuff, followed by a second 50 €?
Please send your opinions.
All the best.
Paolo Cavallini: http://www.faunalia.it/pc
More information about the Qgis-psc mailing list
