[Qgis-psc] Motion: git write access for Etienne Tourigny
Etienne Tourigny etourigny.dev at gmail.com
Wed Jul 11 04:45:15 PDT 2012
On Wed, Jul 11, 2012 at 6:15 AM, Tim Sutton <tim at linfiniti.com> wrote:
> Hi
> On Wed, Jul 11, 2012 at 4:07 AM, Etienne Tourigny
> <etourigny.dev at gmail.com> wrote:
>> Thanks all
>> I will start by committing a slightly modified version of my histogram
>> improvements (in a pull request).
>> Speaking of tests - any idea how the histogram could be tested, and if
>> it's worth it?
> Ideal would be to move histogram logic down into the gui lib as we
> don't yet have a test system in place for app. I could envisage a nice
> call like:
> QSize mySize(800,400);
> QImage myImage = myRasterLayer ->histogramImage(mySize);
> I don't know if that will make sense though given that you are adding
> interactivity to the widget....
>> It think the proper approach would be to generate a reference image
>> and test that it matches, like in the render tests. But not sure this
>> can work with qwt plots though.
> Yes there are a few approaches:
> - use the render checker approach if you expect there render to be
> non-deterministic
> - simply compute a md5 sum if you expect it to be derterministic
I'd expect the images to be correct bit-wise so I would expect
deterministic - but I'm not sure what you mean by deterministic.
>> Generally - how does one make tests that deal with widgets without
>> actually displaying them (like the test environment requires)?
> The test environment can actually deal with gui things - on the test
> server the tests run under a 'fake' X environment. So you could e.g.
> - add a new top level test dir for 'app'
> - create an instance of the raster props dialog
> - open it, set its tab to histogram
> - grab the histogram as an image (I already did code to do that I think)
> - use the render checker to validate the image
> - close everything down again
> Adding app testing is certainly on the roadmap so feel free to forge
> ahead in that direction if you have the time & inclination.
While it would be a great thing, I'm sorry to say that I probably
won't have the time to forge ahead, but I can certainly contribute and
more easily replicate existing methodologies...
cheers
> Regards
> Tim
>> Etienne
>> On Tue, Jul 10, 2012 at 4:28 PM, Sandro Santilli <strk at keybit.net> wrote:
>>> On Tue, Jul 10, 2012 at 08:46:30PM +0200, Tim Sutton wrote:
>>>> Hi
>>>> Thanks all. Etienne you now have write access - please liase with the
>>>> community / Marco before making any major changes, write lots of tests
>>>> and make things stabler, better, faster and more awesome :-)
>>> Please let me stress that out:
>>>  _write_lots_of_tests_
>>> Thank you ! :)
>>> --strk;
> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
> Visit http://linfiniti.com to find out about:
>  * QGIS programming services
>  * Mapserver and PostGIS based hosting plans
>  * FOSS Consulting Services
> Skype: timlinux Irc: timlinux on #qgis at freenode.net
More information about the Qgis-psc mailing list
