[Qgis-psc] Release Name - Was: [Qgis-developer] Reminder: Freeze starts on 2014-01-24 (4 days)
Andreas Neumann a.neumann at carto.net
Thu Mar 27 02:25:34 PDT 2014
And to make things easier you could pick a name in any language - so
either "Köln" or "Cologne" - both would work ;-)
> Some ideas from our discussion during breakfast here on HF in Vienna.
> To get versions order into the code name, we could use the same
> alphabetical schema as Android [1]. Brighton is the good starting
> point. We will regularly return to Essen so we can use it later. That
> means that the next HF location should start with "C".
More information about the Qgis-psc mailing list
