[Qgis-psc] Release Name - Was: [Qgis-developer] Reminder: Freeze starts on 2014-01-24 (4 days)
Gary Sherman gsherman at geoapt.com
Thu Mar 27 07:56:41 PDT 2014
On 3/27/14 1:35 AM, Matthias Kuhn wrote:
> Chamonix starts with C as well
So does Chugiak :)
https://goo.gl/maps/2KIyS
-gary
> On Thu 27 Mar 2014 10:25:34 AM CET, Andreas Neumann wrote:
>> And to make things easier you could pick a name in any language - so
>> either "Köln" or "Cologne" - both would work ;-)
>>> Some ideas from our discussion during breakfast here on HF in Vienna.
>>> To get versions order into the code name, we could use the same
>>> alphabetical schema as Android [1]. Brighton is the good starting
>>> point. We will regularly return to Essen so we can use it later. That
>>> means that the next HF location should start with "C".
>> Qgis-psc mailing list
>> Qgis-psc at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-psc
Gary Sherman
Founder, QGIS Project
Consulting: geoapt.com
Publishing: locatepress.com
We work virtually anywhere
More information about the Qgis-psc mailing list
