[Qgis-psc] QGIS paid bug fixing
Nyall Dawson nyall.dawson at gmail.com
Wed May 27 11:21:02 PDT 2015
On 28 May 2015 2:01 am, "Giovanni Manghi" <giovanni.manghi at gmail.com> wrote:
> http://hub.qgis.org/issues/11371
> Map Composer: group + move + ungroup + undo = crash
Unfortunately this one isn't fixable without major api breakage for
composer. It's on my hit list for the layouts refactor, but can't be fixed
in 2.10
> http://hub.qgis.org/issues/12411 (this is very annoying for all who
> use QGIS server, should be tagged as regression but is not really a
> huge issue because qgis server stil works)
> First call to GetCapabilities after copy of the same .qgs file crashes
> QGIS Server
I'm looking into this one.
> http://hub.qgis.org/issues/12450
> Raster Calculator giving bogus values
I'm happy to add the raster calc issues to my list.
Some others on my list are:
http://hub.qgis.org/issues/12747
Grid frames broken under OSX. I suspect this is not solvable without moving
to Qt5, but it's a high impact issue and I want to confirm that this is the
only fix.
Cleaning up outstanding labeling issues:
Curved labels broken for some scripts. This is a major issue for using QGIS
with certain languages:
http://hub.qgis.org/issues/6883
Rotation related issues:
http://hub.qgis.org/issues/12388
http://hub.qgis.org/issues/12025
Broken repeat distance:
http://hub.qgis.org/issues/11937
Following these I'd like to do a sweep of all normal/low impact
symbology/labeling/ui bugs which can be solved with minimal work... Please
let me know if this is acceptable or if you'd like me to concentrate only
on blockers/high.
I also suspect we'll have to squash a number of regressions relating to the
new geometry engine as they arise.
On a related note, can we put out a widespread call for beta testers? This
has been done in the past and I think it will be good to get as many users
stress testing this new work as soon as possible...
Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20150528/3f972fe9/attachment.html>
More information about the Qgis-psc mailing list
