[Qgis-psc] Sponsored fix report for 2.12
Andreas Neumann a.neumann at carto.net
Thu Oct 22 02:46:08 PDT 2015
Hi Nyall,
This is very impressive! Thank you for the report. Glad you participated
in the sponsored bug fixing program! This time we will try to publish
this in our blog to show users what we do with their donations.
Out of curiosity: Does all of this really fit into the 40h or is there
some extra (unpaid) time involved? Seems almost impossible to me, to be
so efficient ...
Andreas
On 22.10.2015 10:44, Nyall Dawson wrote:
> Hi PSC,
> I've just submitted what I think is the last of my fixes for the 2.12
> release (pending any overnight super-blockers being reported!)
> Here's a summary of what I did during this time. Note that this is a
> bit messy, since it includes both the sponsored fixes + a considerable
> amount of extra volunteer time. But hey, I want to see a good release
> - Sweep of all changed dialogs, ensuring tab order is correct
> - UNREPORTED: Only save effect element if it is non-default (decreases
> size of qgs project files)*
> - HIGH: Fix map rotation not considered for ellipse marker data
> defined rotation (#13367)
> - HIGH: Maintain order of recent expressions (#13461)
> - NORMAL: Make sure recent expression group is always listed last (#13462)
> - NORMAL: [diagrams] Fix initial value of transparency slider not set (#13434)
> - UNREPORTED: Fix potential crashes in renderer widgets
> - NORMAL: Fix legends are empty if presets used with filtered legend (#13300)
> - UNREPORTED: Fix crashes and inconsistent ui when atlas is set to a
> geometryless layer
> - BLOCKER: Fix diagrams are always shown, regardless of setting (#13501)
> - BLOCKER: Fix fill ring tool used with advanced digitising crashes
> QGIS (#13355)
> - NORMAL: Fix add ring/fill ring tool works on first polygon (#13069)
> - BLOCKER: Fix missing sip bindings for renderers (fix #13545)
> - BLOCKER: Fix crash in label property dialog (#13543)
> - NORMAL: Fix hardcoded border for raster legend items (fix #13540)
> - BLOCKER: Fix symbols drawn multiple times in rule based renderer if
> symbol (#13220)
> - BLOCKER: Use a model for node editor table, fixed hang when node
> tool used on large feature (#13541)
> - BLOCKER: Fix node tool duplicates nodes when topological editing and
> snap are both enabled (#13466)
> - NORMAL: Fix broken data defined SVG marker outline width (#13423)
> - HIGH: Scale svg marker outline width to match context (#11522)
> - HIGH: Allow coloring of svg markers and svg fills when used with
> graduated/categorised renderers (#11658)
> - HIGH: Fix svg outline widths are incorrectly scaled (#11522)
> - UNREPORTED: Fix snapping options dialog not correctly initialised
> when loading projects
> - UNREPORTED: Fix uninitialized variables in advanced digitizing dock
> which meant that sometimes advanced digitising tools would be
> activated unexpectedly
> - NORMAL: Fix curved labels ignore line orientation placement flag (f#5778)
> - UNREPORTED: [console] Move run button earlier in console editor
> toolbar (prevents it being hidden in overflow menu on small screens)
> - UNREPORTED: Fix fill and outline color for svg markers sometimes
> enabled even though SVG file does not support parameters
> - UNREPORTED: Fix svg marker colors not correctly restored from project
> - UNREPORTED: If svg files with params do not have a default value
> set, then don't reset the fill/border color and border width when
> changing svg marker/svg fill SVG files (made the behaviour consistent
> between the svg marker and the other marker symbols)
> - NORMAL: Fix svg symbols are shown in white and hard to see in svg
> picker (#10908)
> - NORMAL: Fix refining rule based renderer using expression (#10815)
> - UNREPORTED: Fix crash when changing symbol types on windows
> - BLOCKER: Fix split parts tool only leaves one of the newly created
> parts (#13421)
> - BLOCKER: Fix using add part tool to add part to geometryless rows
> (#12885, #11319)
> - UNREPORTED: Fix some potential crashes with edit tools and null geometry
> - UNREPORTED (thought I'd submitted this years ago but can't find the
> issue now): Allow adding features with empty geometry via attribute
> table
> - HIGH: Allow delete part tool to remove geometry from single type
> point and line layers (#13258)
> - LOW: Fix overview canvas background color not set (#11157)
> - Add some unit tests for QgsWKBTypes
> - NORMAL: When adding ring to a geometry, add z or m dimensions to the
> ring geometry if required (#7400, #7401)
> - NORMAL: Also show features with modified geometry when "show edited
> and new features" filter is active in attribute dialog (#11684)
> - BLOCKER: Fix broken apply button in label config dialog (#13543)
> - BLOCKER: Fix area calculation when OTF active and no ellipsoid, add
> unit test (#13601)
> - UNREPORTED: Fix exporting geometry collections to WKT would result
> in invalid WKT
> - UNREPORTED: Fix unable to import WKT using MultiPoint(1 1,2 2,...) format
> - UNREPORTED: Fix GeometryCollection WKT to support collections with
> multi* children and GeometryCollection children (allowed by spec)
> - Add a bunch of unit tests to geometry
> - UNREPORTED: Fix calculation of area and length of mixed geometry collections
> - UNREPORTED: Fix geometry casting in python bindings (missing
> MultiLineString and GeometryCollection casts)
> - UNREPORTED: Fix calculation of length/perimeter for geometry collections
> - UNREPORTED: when creating geometry from WKT, upgrade dimensionality
> of geometry if coordinates are 3/4 dimensional
> - UNREPORTED: match dimensionality of collections to child dimensionality
> - UNREPORTED: fix area of curves was non-zero if curve is closed
> - UNREPORTED: don't consider m values when testing for curve closedness
> - NORMAL: Fix merge attributes tool sets skipped attributes to null (#13231)
> - NORMAL: Add skip all option to merge attributes dialog (#6958)
> - UNREPORTED: Fix QgsStatisticalSummary sometimes returning 0 for
> StDevSample stat
> - UNREPORTED: Fix storing string representations of doubles in an int
> field results in NULL rather than converting value to int
> - NORMAL: Fix merge attributes/features tool resets values to null for
> int fields and add a warning if merged attribute value is not
> compatible with field type (#12842)
> - Fix a LOT of leaks relating to geometry and GEOS operations, labeling
> - UNREPORTED: [pal] Fix regression in placement for free/horizontal
> polygon labels
> - Add tooltips to advanced digitizing dock
> - Fix a crash in filtered legends
> - Reviewed and merged several bug fix PRs
> So basically I concentrated mainly on blocking geometry, labeling and
> digitising issues, and just generally cleaning up regressions in the
> editing tools. I still need to backport a lot of these fixes to 2.8,
> but I'll wait till after release for that.
> Thanks for sponsoring me again this cycle - I really enjoyed this
> work, and I think 2.12 is in good shape for release. Fingers crossed
> nothing has escaped our testing!
> Nyall
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-psc
More information about the Qgis-psc mailing list
