[Qgis-psc] Sponsored fix report for 2.12
Paolo Cavallini cavallini at faunalia.it
Thu Oct 22 04:17:57 PDT 2015
Nyall: you hero. Hats off!
Thanks so much for your dedication.
Il 22 ottobre 2015 10:44:26 CEST, Nyall Dawson <nyall.dawson at gmail.com> ha scritto:
>Hi PSC,
>I've just submitted what I think is the last of my fixes for the 2.12
>release (pending any overnight super-blockers being reported!)
>Here's a summary of what I did during this time. Note that this is a
>bit messy, since it includes both the sponsored fixes + a considerable
>amount of extra volunteer time. But hey, I want to see a good release
>- Sweep of all changed dialogs, ensuring tab order is correct
>- UNREPORTED: Only save effect element if it is non-default (decreases
>size of qgs project files)*
>- HIGH: Fix map rotation not considered for ellipse marker data
>defined rotation (#13367)
>- HIGH: Maintain order of recent expressions (#13461)
>- NORMAL: Make sure recent expression group is always listed last
>(#13462)
>- NORMAL: [diagrams] Fix initial value of transparency slider not set
>(#13434)
>- UNREPORTED: Fix potential crashes in renderer widgets
>- NORMAL: Fix legends are empty if presets used with filtered legend
>(#13300)
>- UNREPORTED: Fix crashes and inconsistent ui when atlas is set to a
>geometryless layer
>- BLOCKER: Fix diagrams are always shown, regardless of setting
>(#13501)
>- BLOCKER: Fix fill ring tool used with advanced digitising crashes
>QGIS (#13355)
>- NORMAL: Fix add ring/fill ring tool works on first polygon (#13069)
>- BLOCKER: Fix missing sip bindings for renderers (fix #13545)
>- BLOCKER: Fix crash in label property dialog (#13543)
>- NORMAL: Fix hardcoded border for raster legend items (fix #13540)
>- BLOCKER: Fix symbols drawn multiple times in rule based renderer if
>symbol (#13220)
>- BLOCKER: Use a model for node editor table, fixed hang when node
>tool used on large feature (#13541)
>- BLOCKER: Fix node tool duplicates nodes when topological editing and
>snap are both enabled (#13466)
>- NORMAL: Fix broken data defined SVG marker outline width (#13423)
>- HIGH: Scale svg marker outline width to match context (#11522)
>- HIGH: Allow coloring of svg markers and svg fills when used with
>graduated/categorised renderers (#11658)
>- HIGH: Fix svg outline widths are incorrectly scaled (#11522)
>- UNREPORTED: Fix snapping options dialog not correctly initialised
>when loading projects
>- UNREPORTED: Fix uninitialized variables in advanced digitizing dock
>which meant that sometimes advanced digitising tools would be
>activated unexpectedly
>- NORMAL: Fix curved labels ignore line orientation placement flag
>(f#5778)
>- UNREPORTED: [console] Move run button earlier in console editor
>toolbar (prevents it being hidden in overflow menu on small screens)
>- UNREPORTED: Fix fill and outline color for svg markers sometimes
>enabled even though SVG file does not support parameters
>- UNREPORTED: Fix svg marker colors not correctly restored from project
>- UNREPORTED: If svg files with params do not have a default value
>set, then don't reset the fill/border color and border width when
>changing svg marker/svg fill SVG files (made the behaviour consistent
>between the svg marker and the other marker symbols)
>- NORMAL: Fix svg symbols are shown in white and hard to see in svg
>picker (#10908)
>- NORMAL: Fix refining rule based renderer using expression (#10815)
>- UNREPORTED: Fix crash when changing symbol types on windows
>- BLOCKER: Fix split parts tool only leaves one of the newly created
>parts (#13421)
>- BLOCKER: Fix using add part tool to add part to geometryless rows
>(#12885, #11319)
>- UNREPORTED: Fix some potential crashes with edit tools and null
>geometry
>- UNREPORTED (thought I'd submitted this years ago but can't find the
>issue now): Allow adding features with empty geometry via attribute
>table
>- HIGH: Allow delete part tool to remove geometry from single type
>point and line layers (#13258)
>- LOW: Fix overview canvas background color not set (#11157)
>- Add some unit tests for QgsWKBTypes
>- NORMAL: When adding ring to a geometry, add z or m dimensions to the
>ring geometry if required (#7400, #7401)
>- NORMAL: Also show features with modified geometry when "show edited
>and new features" filter is active in attribute dialog (#11684)
>- BLOCKER: Fix broken apply button in label config dialog (#13543)
>- BLOCKER: Fix area calculation when OTF active and no ellipsoid, add
>unit test (#13601)
>- UNREPORTED: Fix exporting geometry collections to WKT would result
>in invalid WKT
>- UNREPORTED: Fix unable to import WKT using MultiPoint(1 1,2 2,...)
>format
>- UNREPORTED: Fix GeometryCollection WKT to support collections with
>multi* children and GeometryCollection children (allowed by spec)
>- Add a bunch of unit tests to geometry
>- UNREPORTED: Fix calculation of area and length of mixed geometry
>collections
>- UNREPORTED: Fix geometry casting in python bindings (missing
>MultiLineString and GeometryCollection casts)
>- UNREPORTED: Fix calculation of length/perimeter for geometry
>collections
>- UNREPORTED: when creating geometry from WKT, upgrade dimensionality
>of geometry if coordinates are 3/4 dimensional
>- UNREPORTED: match dimensionality of collections to child
>dimensionality
>- UNREPORTED: fix area of curves was non-zero if curve is closed
>- UNREPORTED: don't consider m values when testing for curve closedness
>- NORMAL: Fix merge attributes tool sets skipped attributes to null
>(#13231)
>- NORMAL: Add skip all option to merge attributes dialog (#6958)
>- UNREPORTED: Fix QgsStatisticalSummary sometimes returning 0 for
>StDevSample stat
>- UNREPORTED: Fix storing string representations of doubles in an int
>field results in NULL rather than converting value to int
>- NORMAL: Fix merge attributes/features tool resets values to null for
>int fields and add a warning if merged attribute value is not
>compatible with field type (#12842)
>- Fix a LOT of leaks relating to geometry and GEOS operations, labeling
>- UNREPORTED: [pal] Fix regression in placement for free/horizontal
>polygon labels
>- Add tooltips to advanced digitizing dock
>- Fix a crash in filtered legends
>- Reviewed and merged several bug fix PRs
>So basically I concentrated mainly on blocking geometry, labeling and
>digitising issues, and just generally cleaning up regressions in the
>editing tools. I still need to backport a lot of these fixes to 2.8,
>but I'll wait till after release for that.
>Thanks for sponsoring me again this cycle - I really enjoyed this
>work, and I think 2.12 is in good shape for release. Fingers crossed
>nothing has escaped our testing!
>Nyall
>_______________________________________________
>Qgis-psc mailing list
>Qgis-psc at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/qgis-psc
Paolo Cavallini
http://www.faunalia.eu
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20151022/d3a4f936/attachment.html>
More information about the Qgis-psc mailing list
