[Qgis-psc] Moving the issue queue to github
Jürgen E. Fischer jef at norbit.de
Wed Apr 6 03:33:10 PDT 2016
Hi Tim,
On Tue, 05. Apr 2016 at 23:32:39 +0700, Tim Sutton wrote:
> > Can we at least increase the gh counters so that we avoid conflict
> > between ticket numbers?
> Yeah that would be good. I didn’t see an obvious way to start the counter at
> a specific place (other than opening and then closing the tickets as we
> iterate through them). How about if we write a little script to go
> sequentially through the existing ticket range, create a ticket with the text
> “This is a legacy ticket - please see <url to redline issue>” and then
> immediately close the issue? I can do something like that using githubpy[1]…
Something like https://github.com/IQSS/redmine2github looks much more
appropriate to me than trashing what we already have.   But our redmine
apparently doesn't support json output and I'm not sure if it's converting it's
xml output to json would work - I someone else wants to play I downloaded all
the tickets in xml (see http://qgis.org/~jef/tickets.tar.bz2 w/o attachments).
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20160406/ca65744d/attachment.sig>
More information about the Qgis-psc mailing list
