[Qgis-psc] Draft announcement re 3.0
Larry Shaffer larrys at dakotacarto.com
Mon Feb 8 16:58:07 PST 2016
Hi Tim, Jürgen and PSC,
After reviewing this plan I have to say it is an excellent solution to a
no-size-fits-all problem. Thank you for all the consideration and work you
have put into it.
I now have a solid (and indeterminate :^) schedule to present to my
employer, which will help them plan resources to fund further QGIS
development.
It will also help with planning on how/when to produce new nightlies for
Mac.
Regards,
Larry Shaffer
QGIS Support/Development | Boundless
Dakota Cartography
Black Hills, South Dakota
On Mon, Feb 8, 2016 at 7:45 AM, Jürgen E. <jef at norbit.de> wrote:
> Hi Tim,
> On Mon, 08. Feb 2016 at 14:01:12 +0200, Tim Sutton wrote:
> > Thanks Andreas - I’ll just paraphrase the above as another note in the
> > article - should make things a bit clearer!
> Yes.  We do 2.16 with PyQt5/Python3 support next to the existing
> Qt4/PyQt4/Python2 and the existing and widely unused Qt5 support.  So we
> have
> all the smooth, non-breaking steps in master.   We'll still release using
> Qt4/PyQt4/Python2, so that all the plugins keep working.  And people can
> complete stuff that they have already started working on.
> 2.16 will be in the regular 4 months schedule.
> After 2.16 we branch off a qgis3 branch that gets the API changes.  There
> we
> drop Qt4/PyQt4/Python2 support and switch to Qt5/PyQt5/Python3.  Because we
> cannot really estimate if that takes 4, 8 or even more months, we'll work
> on
> that on a "release when ready" scheme an see how it goes and set a date
> when
> qgis3 stabilized.
> The qgis3 branch will be in development so at first we'll probably have
> something that doesn't build at all, requires dependencies that are not
> easy
> available or at least not available on all platforms, while we're at it.
> Because there might be stuff, that can't wait that long, we meanwhile keep
> master open for new features.  The nightlies can keep on going without much
> effort and also regular releases could be done if necessary.
> But master should still considered a dead branch as we is relies on fading
> dependencies and it will be eventually be replaced by the qgis3 (no
> merge).  So
> stuff added to master before will get lost, if it was not also merged or
> redone
> for qgis3.  So people should think twice if they consider to do anything in
> master while we're at qgis3.
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel.
> +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax.
> +49-4931-918175-50
> Software Engineer           D-26506 Norden
> http://www.norbit.de
> QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-psc
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20160208/1661761c/attachment.html>
More information about the Qgis-psc mailing list
