[Qgis-psc] Comments from Strk on QGIS-Testsuite
Sandro Santilli strk at keybit.net
Mon Feb 22 02:23:16 PST 2016
On Fri, Feb 19, 2016 at 09:53:29AM +1100, Nyall Dawson wrote:
> On 17 February 2016 at 21:32, Neumann, Andreas <a.neumann at carto.net> wrote:
> > As you may remember, Strk participated in the paid bug fixing program. He
> > made some comments which I am forwarding to the board:
> > --------------------------- Citing -------------------------------
> > This bugfixing drive convinced me even more that QGIS needs to improve its
> > testsuite framework: it was often difficult to figure out how to provide a
> > test for a bug, there was no provision to write a test before fixing a bug
> > (useful to prove the fix is needed), there is only python testing for the
> > whole PostgreSQL provider and it is not automatically setup to run. Shall
> > there be a budget to improve the situation, please let me know as I have a
> > few ideas.
> To be honest, I'm actually of the opposite view. I think QGIS' test
> suite infrastructure is becoming quite mature and reliable.
I would not call this an "opposite view". I didn't say it become worst
or didn't improve (it did, a lot!). Only I think it should keep improving.
> I think the main problem is that there's little to no documentation of
> the test suite. I often see questions posed by strk on the IRC logs
> regarding the tests but I'm never around at the same time to provide
> answers... but there ARE always answers ;)
There's a "Testsuite" category on the bug tracker.
It currently contains 6 open tickets.
Oldest from October 2 2015, newest from February 17 2016.
All mine, apparently :)
Could tickets be a better way to get answers ?
Looking at those 6 tickets, only one received feedback, probably
because I assigned it to Matthias so he got a notification.
Is there any provision, in redmine, to automatically assign tickets
based on category ? (tickets triaging is probably another place where
projet fundings could be directed).
> Having recently added some unit tests to
> GEOS, I'd strongly argue that writing tests for QGIS is much simpler
> ;) (please don't hate me strk!! ;)
No hate, and I agree knowing a path makes it always shorter.
> For python tests you can mark them as expected failures with
> @unittest.expectedFailure (see
> https://docs.python.org/2/library/unittest.html#unittest.expectedFailure)
It's not clear from the documentation if an unexpected success counts
as a failure. That's what I'm after, so that a fix is immediately
secured in a test rather than left as a discarded test.
> For c++ tests I'd "#ifdef 0" until they are fixed.
Same as above, it won't help noticing that a test does exist.
> I personally don't think this is an issue. Not everyone has access to
> a PostGIS setup for this test to run with, and even if they do they
> may not want running the QGIS test suite to automatically create and
> modify tables on their setup (eg, I would not be happy if the test was
> modifying my production database!!)
The qgis testsuite is using a "qgis_test" database for tests.
Sounds like a safe default. It could be made even safer if you think
it is needed.
Whether or not PostGIS setup is available could be spotted at source
configuration time.
> Again, better test docs would help here.
Surely docs would be an improvement.
> So in summary - I actually think the current test suite setup is good
> (and getting constantly better), and the main problem is both lack of
> testing documentation and training QGIS developers in how to utilise
> it. I'd be happy to run a session during the hackfest explaining all
> this, if that's considered worthwhile...
I'll be there, if available on IRC :)
--strk;
More information about the Qgis-psc mailing list
