[Qgis-psc] QGIS 2.18 bug fixing effort
Giovanni Manghi giovanni.manghi at gmail.com
Mon May 22 08:00:54 PDT 2017
Hi Again,
another regression has hit 2.18.8, this time since 2.18.7
https://issues.qgis.org/issues/16598
"Adding PostGIS layers from the browser or DB-Manager crashes QGIS (mini-dump)"
tested on both Windows and Linux.
-- G --
On Mon, May 22, 2017 at 3:34 PM, Giovanni Manghi
<giovanni.manghi at gmail.com> wrote:
> Hi all,
> this
> https://issues.qgis.org/issues/16593
> has just "entered" the list of regressions (causing crash) in 2.18
> that were ok on 2.14.
> cheers!
> -- G --
> On Fri, May 5, 2017 at 10:14 AM, Giovanni Manghi
>> Hi Andreas and Alexander,
>> the list of regression bugs (excluded the ones affecting ONLY master)
>> and bugs causing crashes or data corruption is here:
>> https://docs.google.com/spreadsheets/d/1frZQU8bwGX499WMvtOc6GDIWqEuSv3QHz3zc90TS46Q/edit?usp=sharing
>> I'm trying to keep it updated as much as I can.
>> There is a column that specifies if the regression has slip into 2.18
>> since 2.14, to me that are the worst bugs as 2.18 will become LTR.
>> Cheers!
>> -- G --
>> On Fri, May 5, 2017 at 10:02 AM, Andreas Neumann <andreas at qgis.org> wrote:
>>> Hi Alex,
>>> Thank you for your reply.
>>> I'll cc Giovanni.
>>> Giovanni - can you please provide Alex a list of processing/analysis related
>>> bugs/regressions - the most pressing ones?
>>> Alex: we'll be happy to pay for a couple of hours. We would be interested in
>>> a regular relationship with core devs who are available to fix the most
>>> pressing issues prior to every release and potentially also after.
>>> Can you estimate - how many hours or days you can dedicate to fixing issues?
>>> I mean within the next 1-2 months and for QGIS 2.18
>>> I'll add you to our list of core devs who participate in our bug fixing
>>> effort then -
>>> https://docs.google.com/spreadsheets/d/1Cdh-6eAmVCdiZIQGMhu_Aqgg09tpxsC40BGXQJtYc54/edit#gid=1281977200
>>> Thanks,
>>> Andreas
>>> On 3 May 2017 at 18:39, Alexander Bruy <alexander.bruy at gmail.com> wrote:
>>>> Hi Andreas,
>>>> 2017-05-03 13:10 GMT+03:00 Andreas Neumann <andreas at qgis.org>:
>>>> > I wonder if you would be interested / would have time - to assist us
>>>> > with
>>>> > our QGIS 2.18 bug fixing efforts - esp. with the processing issues?
>>>> Sure I will be happy to help with this as much as I can.
>>>> > We would pay some devs for up to 5 days (total 40h per dev) with a fixed
>>>> > hourly rate of 100 €. Some devs can only contribute a day or two - which
>>>> > is
>>>> > also fine.
>>>> I would like to donate my time to project.
>>>> Alexander Bruy
>>> Andreas Neumann
>>> QGIS.ORG board member (treasurer)
More information about the Qgis-psc mailing list
