[Qgis-psc] Performance regressions (was QGIS 2.18 bug fixing effort)
ElPaso elpaso at itopen.it
Wed May 24 07:13:56 PDT 2017
Il 24/05/2017 15:19, Matthias Kuhn ha scritto:
> On 5/24/17 2:56 PM, ElPaso wrote:
>> Il 24/05/2017 14:29, Paolo Cavallini ha scritto:
>>> Il 24/05/2017 14:25, Matthias Kuhn ha scritto:
>>>> I think this is still usable (qgis_bench IIRC).
>>>> What it does: give usable measurements when executed on the same
>>>> environment for different projects, different QGIS versions, different
>>>> build parameters, different databases...
>>>> What it not does: produce values that are comparable when executed
>>>> on a
>>>> non-stable system like travis CI. Performance on this system varies
>>>> from
>>>> day to day and we are never sure if a code change or some other change
>>>> on the system (hardware, software, operating system...) is responsible
>>>> for some measured "performance regression".
>>> Thanks Matthias for reminding.
>>> So it would be best to run it in an isolated, predictable environment.
>>> Would a VM do? I think we could find the resources for it, even if this
>>> would require having a dedicated server.
>>> All the best.
>> Maybe a Vagrant configuration to be run on AWS (or any other Vagrant
>> compatible provider).
>> What we probably need is something we can spin up and switch off just
>> for the time required for the test, that's why AWS would fit.
> There are some notes by Radim definitely worth reading (!!) here:
> https://github.com/qgis/QGIS/tree/master/tests/bench
> I think shared environments (most VMs / AWS? / cloud solutions) are
> pointless.
AWS seems pretty repeatable from my experience (if you get an ami with
enough beer), we run several nightly builds and I'd say that the
variance in time is rather low (~2-3%).
> A dedicated server might work but I'd consider even that an
> adventurous project (i.e. worth trying but with no guarantee of
> success ;) )
> Cheers
>> Just my 2 cents.
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
Alessandro Pasotti
w3: www.itopen.it
More information about the Qgis-psc mailing list
