[Qgis-psc] QGIS Soft Feature Freeze Voting (was Re: QGIS 3 release expectations)
Tim Sutton tim at kartoza.com
Tue Nov 28 00:42:10 PST 2017
Hi
> On 28 Nov 2017, at 01:39, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On 27 November 2017 at 08:32, Tim Sutton <tim at kartoza.com> wrote:
>> The voting process is transparent but only qgis/QGIS core committers may vote on it. Please note that if you are eligible you should have received an invite email to join the loomio group. If you did not, please contact me with your preferred email address and I will re-add you.
> Hi Tim,
> What's the process to get exemptions for open PRs? There's a couple
> I'd like to see merged if it's agreeable:
I would propose that we just use the same mechanism - add a motion in loomio then we will have an easily trackable chain of decisions. All the users in the group should be able to raise new proposals to the soft freeze and we can collectively review them on a case by case basis.
How does that sound?
Regards
Tim
> - https://github.com/qgis/QGIS/pull/5600: "Add order by expression
> processing algorithm". Very low risk - it's a self contained algorithm
> on which nothing else depends. Processing in 3.0 is awesome, and has
> made great strides to becoming a competitive ETL tool. This algorithm
> would very nicely complement the work already done in 3.0 to make
> models more powerful and flexible.
> - https://github.com/qgis/QGIS/pull/5430: "More output format choices
> in raster save as dialog": Low risk. Changes only affect the dialog,
> and an extra convenience member in QgsRasterFileWriter (which is
> accompanied by unit tests)
> - https://github.com/qgis/QGIS/pull/5729: "[processing] Expose dynamic
> ("data defined") numeric parameters to gui". Low-medium risk. Most of
> the changes here are gui related, just exposing functionality which
> already exists in the new processing backend (and which is covered by
> stacks of unit tests). I'd love to see this included in 3.0 as it
> changes some of the processing API, and I would like wider testing and
> porting of algorithms to utilise this BEFORE the API is locked in
> place and we're stuck with it. I'd rather identify any issues in the
> related API here for 3.0. Additionally, the changes to the "set z
> value" algorithm which allows the z value to be pulled from a field or
> expression is extremely useful in preparing datasets for use in the
> new 3d views. Plus, it's an absolute KILLER feature to have.
> - https://github.com/qgis/QGIS/pull/5663: "Add a name for transactions
> created from executeSql". It's marked as a feature and tagged as 3.2,
> but looking over it it seems to be almost entirely api tweaks and a
> unit test. I'd say this is low risk, especially given Paul's history
> of stable commits and how well unit tested this are of code is
> already.
> Nyall
Tim Sutton
Co-founder: Kartoza
Project chair: QGIS.org
Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
Desktop GIS programming services
Geospatial web development
GIS Training
Consulting Services
Skype: timlinux
IRC: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20171128/16fb69bd/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20171128/16fb69bd/attachment.jpg>
More information about the Qgis-psc mailing list
