[Qgis-psc] 2018 grant voting is closed
Marco Bernasocchi marco at qgis.org
Tue Jun 19 04:48:37 PDT 2018
Hi Anita, not sure if I found a mistake or if I understand your sheet
wrongly.
The formula used is:
=COUNTIF('Form Responses 1'!B$2:B$25, $B3)
which is the same as the one used in the March 2017 document that had 23
respondents.
shoulden't this year be:
=COUNTIF('Form Responses 1'!B$2:B$31, $B3)
Beside that it looks good to me.
Cheers
Marco
On 19.06.2018 13:05, Andreas Neumann wrote:
> Hi Anita,
> Thanks for organizing the whole QGIS grants thing and for doing the
> scores.
> Even though we communicated 25k € for grants, I think we can also
> commit to 29'5 k. Our financial situation allows it.
> So for me, it would be ok, to communicate the results.
> Personally, I would have had some other priorities than the voting
> results (e.g. infrastructure stuff like "setting registry" or "QGIS
> server OGC compliance ...") are more important to me than "Charts and
> drawings on attribute forms" or "R provider". I also thought that for
> the latter two, are more likely to find alternative financial
> resources - but of course - this is democracy and I will certainly and
> happily also use the "charts and drawings in the forms" - once they
> are available ;-)
> Thanks and greetings,
> Andreas
> On 2018-06-18 11:36, Anita Graser wrote:
>> Hi,
>> The grant voting form is now closed. We received 29 votes from 18
>> community representatives and 11 user group representatives.
>> I've run the numbers to determine the successful proposals but I
>> think we should have at least two more PSC members cross checking the
>> results before publishing them:
>> https://docs.google.com/spreadsheets/d/1e72Z_3jQgCF4cPF6L77W-VptpJX0wSwjFI1TIvGttLU/edit?usp=sharing
>> Please have a look and let me know if you confirm. My plan would be
>> to announce the successful proposals on Sunday 24th June.
>> Regards,
>> Anita
>> Qgis-psc mailing list
>> Qgis-psc at lists.osgeo.org <mailto:Qgis-psc at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/qgis-psc
Marco Bernasocchi
QGIS.org Co-chair
http://berna.io
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20180619/7d1ecc84/attachment.html>
More information about the Qgis-psc mailing list
