[Qgis-psc] Documents for AGM
Paolo Cavallini cavallini at faunalia.it
Tue Feb 26 00:40:04 PST 2019
Thanks Andreas and Tim for the review.
Sending off now. Another good step forward, in our 17th anniversary.
All the best.
On 26/02/19 09:20, Andreas Neumann wrote:
> Hi Paolo and colleagues,
> I finished the documents you should send along with the AGM invitation:
> - financial report (PDF), see
> https://drive.google.com/open?id=10_RQEniCuESfyhZhXoHpLfpXwyRrr7uv
> - financial auditing report (PDF), see
> https://drive.google.com/open?id=1v5Tsa-wa6smBSQ0u2KnabNzBnY5bayV1
> - revision of our statutes (PDF) - also checked by Tim. See
> https://drive.google.com/open?id=14gez-_EWZnKTUuNbNsJr8I0jwpBAYDOV
> In addition, Tim and I worked on the AGM invitation itself
> (https://drive.google.com/open?id=1kGDfOyNK08zaGh70erjGNmYKcFQTAdDxkwLYFH21lA8
> ). I also checked the annual report 2018
> (https://drive.google.com/open?id=114ofo3juxXFCKPVBqFuYIz8MB1xhBdXifo9e54V7ovU
> ) and removed the financial report from the appendix. I think it is
> better to have them as two separate documents.
> I think that now we are good to send out the AGM invitation to the
> voting members.
> Thanks and greetings,
> Andreas
> Andreas Neumann
> QGIS.ORG <http://QGIS.ORG> board member (treasurer)
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
Paolo Cavallini - www.faunalia.eu
QGIS.ORG Chair:
http://planet.qgis.org/planet/user/28/tag/qgis%20board/
More information about the Qgis-psc mailing list
