[Qgis-psc] [QGIS-Developer] Phasing out 32-bit support in QGIS for
Jürgen E. Fischer jef at norbit.de
Fri Oct 16 02:42:10 PDT 2020
Hi Nyall,
On Fri, 16. Oct 2020 at 10:19:58 +1000, Nyall Dawson wrote:
> > tl;dr QGIS will drop 32-bit support on Windows after the QGIS 3.16 release
> > when we update our Qt dependencies to Qt 5.15.
> Am I right in interpreting that this means the Windows packaging
> improvements won't land till after 3.16 is released?
It looks like it.  I'm in the middle of the osgeo4w reboot, but I'm not sure if
I'll make it before the release.  Even if I do, there will be only very
limited time for testing, if any - so it's probably better to do the next
release as is and switch after (and drop 32bit completely for everything).
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20201016/5d58c1d0/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20201016/5d58c1d0/attachment.ksh>
More information about the Qgis-psc mailing list
