[Qgis-psc] Schedule for 2021 grants
Anita Graser anitagraser at gmx.at
Wed Jan 6 07:50:31 PST 2021
Ok, I'll try to get things rolling in January.
Andreas, could you have a look if the update calendar is correct from
the budget perspective?
Regards,
Anita
On 06.01.2021 15:02, Alessandro Pasotti wrote:
> Good idea!
> On Wed, Jan 6, 2021 at 2:57 PM Andreas Neumann <andreas at qgis.org> wrote:
>> Hi Anita,
>> Yes, I think it would be great to start earlier - asap.
>> This increases the chance that the projects are actually finished during the same year, which hasn't been the case in 2020 ;-(
>> Andreas
>> On Wed, 6 Jan 2021 at 13:15, Anita Graser <anitagraser at gmx.at> wrote:
>>> Dear fellow PSC members,
>>> Since we already have an approved budget this year thanks to Andreas'
>>> efforts, do you think we should also start the grant process earlier?
>>> (Usually, we started the grant process in April, as documented in the
>>> calendar (which may need some updating) at:
>>> https://docs.google.com/document/d/17N9j6s7IWZIzxPJXZbgo2z1qADWrOu6Avt7DIN8rFVk/edit?usp=sharing)
>>> Regards,
>>> Anita
>>> Qgis-psc mailing list
>>> Qgis-psc at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/qgis-psc
>> Andreas Neumann
>> QGIS.ORG board member (treasurer)
More information about the Qgis-psc mailing list
