[Qgis-psc] Handling the Travis CI situation
Marco Bernasocchi marco at qgis.org
Fri Jan 29 00:13:23 PST 2021
perfect thanks.
let us know if you need anything else.
re the docker image i think we could potentially set up a registry?
cheers
On Fri, 29 Jan 2021, 08:59 Alessandro Pasotti, <apasotti at gmail.com> wrote:
> Sounds good!
> How do we solve the Docker Hub problem? I abandoned the idea to ask
> for a free tier after Nyall's comment.
> Can we put the exported image on one of our qgis* servers?
> On Fri, Jan 29, 2021 at 8:41 AM Matthias Kuhn <matthias at opengis.ch> wrote:
> > On Thu, Jan 28, 2021 at 11:37 PM Nyall Dawson <nyall.dawson at gmail.com>
> wrote:
> >> On Fri, 29 Jan 2021 at 08:28, Marco Bernasocchi <marco at qgis.org> wrote:
> >>> Hi all, no need to vote again, the budget was approved and it included
> an item for working on CI.
> >>> So the funds are available. I spoke about this yesterday with Andreas
> following up a request by Denis.
> >>> Nyall do I see it correctly that you and Denis (and Alessandro?) are
> probably the ones going to be doing most of the work?
> >>> Do you have a concrete plan and how can we help getting things moving?
> >> I'll chat to Denis and Alessandro again later today, but originally
> we'd discussed using Denis' earlier PR to move to Gtihub actions and have
> Denis do the remaining bits needed for this, and then splitting the test
> fixes between myself, Denis and Alessandro based on the area of code
> covered by the failing tests. (I.e. I'll handle the
> symbology/labeling/print layout and projection related ones, Alessandro
> would focus on server, etc).
> >> I'd propose that we:
> >> 1. Get Denis' earlier PR rebased and working on master again
> >> 2. Blocklist all the failing tests on the github action, and then merge
> the PR so that we get some test coverage outside of Travis
> >> 3. Chip away re-enabling the individual blocklisted tests one-by-one
> >> Nyall
> > Good plan, it would be nice to start with this soon
> > Matthias
> > Qgis-psc mailing list
> > Qgis-psc at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/qgis-psc
> Alessandro Pasotti
> QCooperative:  www.qcooperative.net
> ItOpen:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20210129/ddcfe619/attachment.html>
More information about the Qgis-psc mailing list
