[Qgis-psc] Call for reviews of grant programme voting results
Régis Haubourg
regis.haubourg at gmail.com
Sun Jun 18 04:24:26 PDT 2023
Hi Anita,
thanks a lot for this work.
I double checked and all results look good to me.
Cheers
Régis
On 15/06/2023 19:22, Anita Graser via QGIS-PSC wrote:
> Dear fellow PSC members,
> The voting for the 2023 grant programme has closed and I have
> calculated the results.
> As specified in the process description, the computations should be
> reviewed and confirmed by at least two PSC members. Therefore, I'd
> like to invite you to have a look.
> For your convenience, here's the summary of the process:
> The successful proposals are determined as follows: The calculation of
> votes is done by summing up the votes for each proposal. We then rank
> each proposal according to the number of votes it has received.
> Grants will be allocated by working sequentially from top scoring
> proposal to lowest until all the funds have been allocated. If the top
> candidates do not exactly coincide with the total grant budget, we
> may, depending on available funds, ‘top up’ the grant budget to
> include the next-in-line proposal and use up all of the available
> funds. The Google Drive GrantProgramme folder contains spreadsheets
> with the corresponding formulas.
> The computed results should be reviewed and confirmed by at least two
> PSC members before publishing the results.
> Regards,
> Anita
> Anita Graser
> Home: http://anitagraser.com
> Twitter: @underdarkgis
> Mastodon: @underdarkgis at fosstodon.org
> QGIS-PSC mailing list
> QGIS-PSC at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20230618/0bb65949/attachment.htm>
More information about the QGIS-PSC
