[Qgis-psc] QGIS grant report: Improve test result handling on QGIS CI
Sandro Santilli strk at kbt.io
Wed Jan 3 11:24:14 PST 2024
On Mon, Nov 27, 2023 at 05:09:07PM +1000, Nyall Dawson via QGIS-PSC wrote:
> On Mon, 27 Nov 2023, 4:56 pm Alessandro Pasotti, <apasotti at gmail.com> wrote:
> > https://github.com/qgis/QGIS/pull/55417#issuecomment-1826995755
> > comment the instructions say:
> > "The full test report (included comparison of rendered vs expected
> > images) can be found under the 'Checks' tab - 'QGIS tests',
> > 'Artifacts' section as test-results-5."
> > But I couldn't find any test-results-5 in the artifacts section
> That's caused by a limitation in GitHub API.
Would it be possible for that comment to contain instruction about how
to run that test locally ? Helping developers running failing tests
locally would reduce load on shared infrastructure.
--strk;
More information about the QGIS-PSC mailing list
