[QGIS-pt] Boas
Vinicius Silva x3msnake gmail.com
Quarta-Feira, 17 de Dezembro de 2014 - 15:16:55 PST
o Qt é escrito em quê?
No dia 17 de dezembro de 2014 às 23:06, Alexandre Neto <
senhor.neto  gmail.com> escreveu:
> Aqui vai a resposta do Nyall.
> Aparentemente a implementação do CMYK terá de ser feita primeiro no Qt
> (que é a framework sobre a qual o qgis está criado).
> E ao que parece os últimos pedidos nesse sentido não surtiram grande
> efeito. Não sabemos se no caso do Qt é possível patrocinar este tipo de
> melhorias.
> On 18 December 2014 at 01:31, Alexandre Neto <senhor.neto  gmail.com>
> wrote:>> Hello everyone,>> Does anyone know if there are any plans for
> implementing CMYK color mode in> QGIS?I did a bit of research yesterday and
> it looks like we're out of luckuntil the underlying Qt libraries (QPainter,
> QPrinter, QtSvg) gainsupport for CMYK. We could add support for selecting
> CMYK colours intothe new colour picker, but currently all of the export
> optionsavailable in Qt convert colours back to RGB prior to export.> If
> there are no plans for that, can someone give me anideia of what would>
> need to be done?It would need to be implemented in Qt, but I can't find
> muchinformation about whether this is planned or not. Here's a couple
> ofrelevant reports (with almost zero activity):
> https://bugreports.qt-project.org/browse/QTBUG-896https://bugreports.qt-project.org/browse/QTBUG-86https://bugreports.qt-project.org/browse/QTBUG-21276I'm
> also not sure if Qt has a culture of sponsored targeteddevelopment, or who
> you could get to tackle this... I'm interested toknow any findings you have
> though, as there's a number of similar Qtlimitations which really hold us
> back:
> https://bugreports.qt-project.org/browse/QTBUG-28636https://bugreports.qt-project.org/browse/QTBUG-36302https://bugreports.qt-project.org/browse/QTBUG-6582(also
> there's a report that I can't find right now about allowingediting of PDF
> metadata)Nyall
> Em 16/12/2014 07:21, "Luigi Pirelli" <luipir  gmail.com> escreveu:
> Hola Alexander,
>> envia el correo tambien en qgis-developer para fomentar la discusión
>> ciao Luigi Pirelli
>> 2014-12-16 0:46 GMT+01:00 Alexandre Neto <senhor.neto  gmail.com>:
>>> Boa noite,
>>> Já mandei um email ao Nyall a saber se existem planos para a introdução
>>> do CMYK no QGIS, e o que seria preciso para o implementar.
>>> Vamos ver o que ele responde.
>>> Abraço,
>>> Alexandre Neto
>>> 2014-12-15 19:34 GMT+00:00 Vinicius Silva <x3msnake  gmail.com>:
>>>> Aqui está mais uma biblioteca que tem muito potencial, se integrada com
>>>> o Qgis
>>>> [image: Tree]
>>>> http://xxyxyz.org/flat
>>>> No dia 15 de dezembro de 2014 às 19:30, Vinicius Silva <
>>>> x3msnake  gmail.com> escreveu:
>>>>> Boas Luigi
>>>>> Encontrei uma biblioteca de gestão de cores que penso pode ser um meio
>>>>> para acelerar o processo de criação de um Plug ou integração do CMYK no
>>>>> http://www.cazabon.com/pyCMS/
>>>>> http://unix.stackexchange.com/questions/22193/how-can-i-generate-cmyk-images-via-the-command-line-under-linux
>>>>> Vou então perguntar no freenode. Thanks
>>>>> Abraços Master Luigi
>>>>> No dia 15 de dezembro de 2014 às 18:45, Luigi Pirelli <
>>>>>> Hola vinicius, el paso es ir al irc de freenode #qgis y preguntar
>>>>>> allí en inglés, creo que marco y nyall te pueden decir exactamente la parte
>>>>>> de código relacionada con cmyk.
>>>>>> Esto para empezar... Y después en qgis-developer que seguro hay
>>>>>> personas interesadas. Cuenta que seguro puede crear un pledge para
>>>>>> financiarte el desarrollo.
>>>>>> Cual Luigi Pirelli
>>>>>> On Monday, 15 December 2014, Hugo <hfpmartins  gmail.com> wrote:
>>>>>>> Olá Vinicius,
>>>>>>> Bem vindo...
>>>>>>> Vamos esperar a ver se o Alex sabe onde isso está. Caso contrário
>>>>>>> logo te ajudo a encontrar esse pedaço de código.
>>>>>>> O plugin pode ser uma ideia... mas fixe fixe era isso entrar para o
>>>>>>> core do QGIS. O Alex ficou de falar com o developer que anda mais activo
>>>>>>> nessa componente para saber como está a coisa. Vamos esperar um pouco pelo
>>>>>>> feedback.
>>>>>>> Grande abc,
>>>>>>> No dia 15 de dezembro de 2014 às 14:05, Vinicius Silva <
>>>>>>>> Boas Pessoal
>>>>>>>> Já cá estou inscrito ;)
>>>>>>>> Em que parte ou partes do Source Code do Qgis está o sistema de
>>>>>>>> cores?
>>>>>>>> Gostava de dar uma vista de olhos para tentar compreender se será
>>>>>>>> muito difícil adaptar o sistema para usar cores CMYK em vez das cores de
>>>>>>>> sistema.
>>>>>>>> Caso contrario poderia-se produzir um plugin de exportação que
>>>>>>>> identifique as cores utilizadas e permita ao utilizador indicar quais as
>>>>>>>> cores.
>>>>>>>> Seria interessante ter exportação para PDF em CMYK Georeferenciado
>>>>>>>> Com os melhores cumprimentos,
>>>>>>>> Vinicius Silva
>>>>>>>> _______________________________________________
>>>>>>>> QGIS-pt mailing list
>>>>>>>> QGIS-pt  lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/qgis-pt
>>>>>>> Hugo Martins
>>>>> Vinicius Silva
>>>> Vinicius Silva
Vinicius Silva
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/qgis-pt/attachments/20141217/f45c2262/attachment-0001.html>
More information about the QGIS-pt mailing list
