[QGIS-pt] imagens raster
Fábio Rita fabio.batista21 hotmail.com
Quinta-Feira, 31 de Julho de 2014 - 04:37:58 PDT
seguindo os passos que me disse, deu o seguinte resultado:
Driver: GTiff/GeoTIFF
Files: C:/Users/fabio.rita/Desktop/Vectorizacao_PDM/Planta_condicionantes_papel/PC_parte_1/planta_condicionantes_papel1.tif
       C:/Users/fabio.rita/Desktop/Vectorizacao_PDM/Planta_condicionantes_papel/PC_parte_1/planta_condicionantes_papel1.tif.ovr
       C:/Users/fabio.rita/Desktop/Vectorizacao_PDM/Planta_condicionantes_papel/PC_parte_1/planta_condicionantes_papel1.tif.aux.xml
Size is 13036, 18192
Coordinate System is:
PROJCS["ETRS89_Portugal_TM06",
    GEOGCS["GCS_ETRS_1989",
        DATUM["European_Terrestrial_Reference_System_1989",
            SPHEROID["GRS_1980",6378137.0,298.257222101]],
        PRIMEM["Greenwich",0.0],
        UNIT["Degree",0.0174532925199433]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["false_easting",0.0],
    PARAMETER["false_northing",0.0],
    PARAMETER["central_meridian",-8.133108333333334],
    PARAMETER["scale_factor",1.0],
    PARAMETER["latitude_of_origin",39.66825833333333],
    UNIT["Meter",1.0]]
Origin = (0.000000000000000,45.480000000000004)
Pixel Size = (0.002500000000000,-0.002500000000000)
Metadata:
  TIFFTAG_IMAGEDESCRIPTION=
  TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
  TIFFTAG_XRESOLUTION=400
  TIFFTAG_YRESOLUTION=400
Image Structure Metadata:
  COMPRESSION=LZW
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (   0.0000000,  45.4800000) (  8d 7'59.19"W, 39d40' 7.20"N)
Lower Left  (   0.0000000,   0.0000000) (  8d 7'59.19"W, 39d40' 5.73"N)
Upper Right (  32.5900000,  45.4800000) (  8d 7'57.82"W, 39d40' 7.20"N)
Lower Right (  32.5900000,   0.0000000) (  8d 7'57.82"W, 39d40' 5.73"N)
Center      (  16.2950000,  22.7400000) (  8d 7'58.51"W, 39d40' 6.47"N)
Band 1 Block=13036x512 Type=Byte, ColorInterp=Red
  Overviews: 6518x9096, 3259x4548, 1630x2274, 815x1137, 408x569, 204x285
Band 2 Block=13036x512 Type=Byte, ColorInterp=Green
Band 3 Block=13036x512 Type=Byte, ColorInterp=Blue
Desde já muito obrigado pela atenção.
Fábio
> Date: Thu, 31 Jul 2014 12:25:34 +0100
> From: giovanni.manghi  faunalia.pt
> To: qgis-pt  lists.osgeo.org
> Subject: Re: [QGIS-pt] imagens raster
> raster -> miscellaneous -> information
> e cola aqui o resultado
> 2014-07-31 12:23 GMT+01:00 Fábio Rita <fabio.batista21  hotmail.com>:
> > Boa Tarde,
> > Georreferenciei duas imagens raster em formato TIFF no ArcGis. Agora, ao
> > colocá-las no QGis parece-me que perderam a georreferenciação, uma vez, que
> > as imagens aparecem sobrepostas, quando deveriam surgir lado a lado. Além
> > disso, também há uma distorção das imagens e a vectorização feita sobre
> > essas imagens não surgem sobre as imagens.
> > Será possível que o QGis não reconheça a georreferenciação efectuada noutro
> > programa, se faz favor?
> > Muito obrigado pela atenção,
> Giovanni Manghi
> Faunalia.pt
> Sistemas de Informação Geográfica Open Source
> Portugal
> Web: http://www.faunalia.pt
> Email & Jabber: giovanni.manghi  faunalia.pt
> PGP Key available
> Tel. + 351 96 7058216
> QGIS-pt mailing list
> QGIS-pt  lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/qgis-pt
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/qgis-pt/attachments/20140731/bbb71092/attachment.html>
More information about the QGIS-pt mailing list
