[qgis-qwc2] Projection issue with QWC2
Sandro Mani manisandro at gmail.com
Thu Mar 1 04:48:59 PST 2018
Hi Sebastain
What extent does the generated themes.json contain?
Best
Sandro
On 01.03.2018 13:40, GOERKE Sebastian wrote:
> Hi Sandro,
> the themesConfig.json does not contain extent information, so QWC2
> should use the extent from the QGIS Server, right? But there is
> something going wrong then. The extent of the WMS is an area in
> Germany and I want QWC2 to use that. Instead the QWC2 client shows an
> area around the Ukraine. I tried some configuration like switching the
> default WMS version because I am aware of the different axis order
> handling between 1.1.1 and 1.3.0 but nothing changed.
> What´s interesting about my QGIS Server WMS is that x and y axis are
> interchanged in version 1.3.0 following my understanding that x is
> longitude and y is latitude.  But the WMS service works correctly
> while using it within QGIS. So, for me, there is an issue within the
> configuration of my QWC2 instance or within the interpretation of the
> extents within the WMS.
> The question is, which adjustments can I make to solve the issue or
> how I can identify the reason for the wrong behavior.
> Best Regards
> Sebastain
> **Sebastian GOERKE*
> Consultant
> *Sopra Steria Consulting***
> Sopra Steria AG
> Barcelona-Allee 1
> 51103 Köln - Deutschland
> Phone: +49 221 92404-8958 - Mobile: +49151 40625945
> sebastian.goerke at soprasteria.com
> <mailto:sebastian.goerke at soprasteria.com> - www.soprasteria.de
> <http://www.soprasteria.de/>
> <https://www.linkedin.com/company/soprasteria><https://www.facebook.com/soprasteria.de><https://twitter.com/SopraSteria_de><https://www.xing.com/company/soprasteria><http://digitale-exzellenz.de/>
> Before printing, think about the environment.
> The content of this message may be confidential, legally privileged
> and protected by law. Unauthorized use, copying or disclosure of any
> of it may be unlawful. If you are not the intended recipient please
> notify the sender and remove it from your system. While attachments to
> this e-mail are checked for viruses, we do not accept any liability
> for any damage sustained by viruses.
> *Von:*qgis-qwc2 [mailto:qgis-qwc2-bounces at lists.osgeo.org] *Im Auftrag
> von *Sandro Mani
> *Gesendet:* Donnerstag, 1. März 2018 13:16
> *An:* qgis-qwc2 at lists.osgeo.org
> *Betreff:* Re: [qgis-qwc2] Projection issue with QWC2
> Hi
> Is the extent being overridden in themesConfig.json? If not, the
> initial extent is just read from the WMS capabilities, i.e.
> EX_GeographicBoundingBox of the root layer. Also, make sure that the
> used projection appropriate for Ukraine.
> Sandro
> On 01.03.2018 08:55, GOERKE Sebastian wrote:
>     Hi all,
>     I am currently trying a bit arround with qwc2 and it seems for us
>     to be a perfect solution for several customers, as the data
>     specific part can more or less completely be done within QGIS
>     itself by the customers.
>     Now I am facing issues with map projections. The client sets a
>     bbox around the Ukraine instead of Middle-Europe. I checked the
>     QGIS Server WMS Capabilities and tested the WMS service by adding
>     it to QGIS and everything works just fine. Even if I pan to
>     Germany within my QWC2 map, the layers are displayed correctly. It
>     is just the initial bbox within the client which is strange.
>     Within the attachment you can find the capabilities file from QGIS
>     Server and my themesConfig.json. Maybe someone has an idea what my
>     issue is about J
>     Best Regards
>     Sebastian
>     **Sebastian GOERKE*
>     Consultant
>     Sopra Steria AG
>     Barcelona-Allee 1
>     privileged and protected by law. Unauthorized use, copying or
>     disclosure of any of it may be unlawful. If you are not the
>     intended recipient please notify the sender and remove it from
>     your system. While attachments to this e-mail are checked for
>     viruses, we do not accept any liability for any damage sustained
>     by viruses.
>     Sopra Steria Consulting is the trading name of:
>     Sopra Steria AG - Vorsitzender des Aufsichtsrates: Vincent Paris -
>     Vorstand: Urs Michael Krämer - Sitz der Gesellschaft: Hamburg - HR
>     B 148540 Amtsgericht Hamburg - USt-ID-Nr.: DE118671351
>     _______________________________________________
>     qgis-qwc2 mailing list
>     qgis-qwc2 at lists.osgeo.org <mailto:qgis-qwc2 at lists.osgeo.org>
>     https://lists.osgeo.org/mailman/listinfo/qgis-qwc2
> Vorstand: Urs Michael Krämer - Sitz der Gesellschaft: Hamburg - HR B
URL: <http://lists.osgeo.org/pipermail/qgis-qwc2/attachments/20180301/0eb88bcc/attachment-0001.html>
More information about the qgis-qwc2 mailing list
