[Qgis-release-team] Re: [Qgis-community-team] Re: [Qgis-developer] QGIS 1.2.0 Branched - Call for packaging
Anne Ghisla a.ghisla at gmail.com
Wed Aug 26 08:53:43 EDT 2009
Il giorno mer, 26/08/2009 alle 14.39 +0200, Otto Dassau ha scritto:
> Hi Anne,
> On Wed, 26 Aug 2009 14:36:12 +0200
> Anne Ghisla <a.ghisla at gmail.com> wrote:
> > Working on that now. I'm moving the VisualChangelog pages from old wiki
> > to new one, but there is a different way to format unformatted text. On
> > mediawiki it requires a space at the beginning of each line, instead of
> > triple-bracketing the whole text as moinmoin does.
> > Shall I add all spaces, or just keep the text as it is, and we will pick
> > up the source to convert it to html, disregarding actual page layout?
> > ok, it's just a appearance issue.. but an advice is appreciated.
> txt2tags also supports mediawiki in newer versions, if you still have the
> original t2t files. If you don't want to install it you can use the webtool:
> http://txt2tags.sourceforge.net/online.php
Great to know, but the question is slightly different:
We used to keep the changelog in text format in a wiki page, using the
triple curly brackets to keep it unformatted. For that purpose,
mediawiki requires a more invasive markup. So I was asking what it is
better to do, disregard wiki rendering and focus on source or, as you
suggested, convert the text changelog in mediawiki format.
regards,
Anne
Name: not available
Desc: Questa =?ISO-8859-1?Q?=E8?= una parte del messaggio
	firmata digitalmente
Url : http://lists.osgeo.org/pipermail/qgis-release-team/attachments/20090826/d2af9f9a/attachment-0001.bin
More information about the Qgis-release-team mailing list
