[Qgis-release-team] Re: [Qgis-community-team] Re:
[Qgis-developer] QGIS 1.2.0 Branched - Call for packaging
Otto Dassau
otto.dassau at gmx.de
Wed Aug 26 09:03:09 EDT 2009
On Wed, 26 Aug 2009 14:53:43 +0200
Anne Ghisla <a.ghisla at gmail.com> wrote:
> Il giorno mer, 26/08/2009 alle 14.39 +0200, Otto Dassau ha scritto:
> > Hi Anne,
> > On Wed, 26 Aug 2009 14:36:12 +0200
> > > Working on that now. I'm moving the VisualChangelog pages from old wiki
> > > to new one, but there is a different way to format unformatted text. On
> > > mediawiki it requires a space at the beginning of each line, instead of
> > > triple-bracketing the whole text as moinmoin does.
> > > Shall I add all spaces, or just keep the text as it is, and we will pick
> > > up the source to convert it to html, disregarding actual page layout?
> > > ok, it's just a appearance issue.. but an advice is appreciated.
> > txt2tags also supports mediawiki in newer versions, if you still have the
> > original t2t files. If you don't want to install it you can use the webtool:
> > http://txt2tags.sourceforge.net/online.php
> Great to know, but the question is slightly different:
> We used to keep the changelog in text format in a wiki page, using the
> triple curly brackets to keep it unformatted. For that purpose,
> mediawiki requires a more invasive markup. So I was asking what it is
> better to do, disregard wiki rendering and focus on source or, as you
> suggested, convert the text changelog in mediawiki format.
instead of adding all space inmediawiki you can use <pre> text </pre> ...
better ? :)
Otto
> regards,
> Anne
More information about the Qgis-release-team
