[Qgis-tr] Re: Translating for android
Marco Bernasocchi marco at bernawebdesign.ch
Mon Nov 28 19:59:51 EST 2011
Hi Guys, I just developed an installer for android. It has 11 strings to
be translated, I was wondering if you guys can help me. it is a simple
xml where there is only one language in it.
If you are friends of git, you can fork the repo [0], duplicate the
values folder (installer-apk/res/values/) and call it values-lang
(example values-it) and then send a pull request.
If this sounds to complicated, You can find the file here [1] and you
can just add a comment with the traduction or send me a mail.
Aswell, under apk/res/values/strings.xml there are 2 strings
(done_unpacking_msg and unpacking_msg) to be translated.
Thanks a lot for your help
ciao marco
[0]: https://github.com/qgis/qgis-android
[1]: https://gist.github.com/1402619
Marco Bernasocchi
www.opengis.ch
More information about the Qgis-tr mailing list
