[Qgis-tr] Hackfest
Artem Popov artfwo at gmail.com
Wed Apr 18 05:04:35 EDT 2012
2012/4/15 Werner Macho <werner.macho at gmail.com>:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi Translators!
> So just the necessary news brought to you directly from the hackfest
> in Lyon..
> There have been discussions about the release-cycle of QGIS
> Here are the necessary facts for translators:
> We will stick closely to master -> meaning that there is no need to
> look after 1.7.x 1.8.x ... and all those other different branches..
> - From now on just try to stick as closely as possible to the master
> branch. Try to keep up with the changes .. request a string update as
> soon as you think you have a need for it.
> We'll sort out a lot of things and probably 1.8 will look like a lot
> different than we assumed it to have half a year ago when the branch
> was branched out of master ..
> I hope is in our all interest to ease life as much as possible .. and
> only have to stick to master would ease that a lot (also for me).
> The second part I would like to ask .. If you will have a closer look
> to master there is a new Translators dialog in the Help -> About Box ..
> I would like to make the name of each Translation Teamleader clickable
> to directly get in contact with the Teamleader. That I think would
> open the way for directly reporting typos and other things in QGIS to
> get fixed in translations.
> Do you all think it will be a good idea or are you thinking that would
> not change a lot?
> And - very important .. are you all ok with it to have your email
> inside the About box?
No problem for me either. Also, just sent a pull request for the RU
draft to the master branch. Check it out!
Kind regards,
--Artem
More information about the Qgis-tr mailing list
