[Qgis-tr] Transifex!
Werner Macho werner.macho at gmail.com
Tue Apr 23 22:10:28 PDT 2013
Hi Jean Roc!
As there is still no clear workflow from transifex to QGIS Source I
would ask to stick to "normal" translation for now.
So just use git, linguist and the ts file for the next while ..
As soon as we find a useable way to not loose any translation I will
announce it on the mailing list that you should switch/use both.
thanks a lot
Werner
On 23/04/13 23:52, MORREALE Jean Roc wrote:
> Hi Werner,
> I've been out of the loop for a while, can you point me to a
> documentation of the new ui translating process ?
> I may be able to work on it for a few days, should I do the old
> git/linguist way or via transifex ?
> regards,
> jean-roc
> Qgis-tr mailing list
> Qgis-tr at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-tr
More information about the Qgis-tr mailing list
