[Qgis-tr] Norwegian Bokmål Translation
Jacob Overgaard Madsen u2jacob at gmail.com
Thu Jul 4 09:05:38 PDT 2013
Credits to you, if you take this task (speaking of experience). Please, go
ahead and see, if you can use my Danish translation, depending on how
strong your Danish is (My Norwegian is not). Also, let me know, if you have
any comments to it.
Jacob
2013/7/4 Werner Macho <werner.macho at gmail.com>
> Hi!
> Yeah .. the address is correct ..
> Regarding the two language codes .. well .. you should know better than me
> If you want I can create the file for you .. which will be the
> qgis_no_NB.ts file if i understood you correctly
> But you can also start with the existing one and i am going to rename
> it once you sent it to me for committing it ..
> Or are you going to make pull request .. that way I would rename it
> first before you start .. would be much easier for you than
> thanks a lot again for taking this task
> kind regards
> Werner
> On Thu, Jul 4, 2013 at 4:12 PM, Stott James <fmrojst at fylkesmannen.no>
> wrote:
> > Thanks for the advice Jacob and Werner. I think the Danish translation
> could
> > be a good place to start you are correct.
> > Two quick questions:
> > One, is it here I check the code out from?
> > https://github.com/qgis/Quantum-GIS.git
> > And two, I notice that there is a qgis_no.ts file already there.
> > Seeing as there are two Norwegian languages (Bokmål and Nynorsk), would
> it
> > be best to create two new .ts files like Portuguese has pt_BR and pt_PT?
> > So for Norwegian it would be:
> > qgis_no_NB.ts
> > qgis_no_NN.ts
> > Or do I edit the existing file somehow?
> > Ideally both would be supported, but I think I have my work cut out with
> > Bokmål to start with.
> > Regards,
> > James Stott
> > Qgis-tr mailing list
> > Qgis-tr at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-tr
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20130704/0361d696/attachment.html>
More information about the Qgis-tr mailing list
