[Qgis-tr] Follow up to the String Freeze!
Artem Popov artfwo at gmail.com
Wed Jul 17 20:11:21 PDT 2013
Typos in src/plugins/topology/topolTest.cpp, function checkDanglingLines:
276: QgsMessageLog::logMessage( tr( "First geometry invalid in line
test." ), tr( "Topology plugin" ) );
282: QgsMessageLog::logMessage( tr( "Failed to import first geometry
into GEOS in line test." ), tr( "Topology plugin" ) );
compare function checkDuplicates:
408: QgsMessageLog::logMessage( tr( "Invalid second geometry in
dangling line test." ), tr( "Topology plugin" ) );
414: QgsMessageLog::logMessage( tr( "Failed to import second geometry
into GEOS in dangling line test." ), tr( "Topology plugin" ) );
The second pair of strings should probably mention that it's a
duplicate geometry test and the first that it's a dangling line test.
-Artem
2013/7/3 Werner Macho <werner.macho at gmail.com>:
> Hi Translators!
> I hope everything is working well during your hard work..
> A matter that I just wanted to tell you is:
> Considering typos in the original language
> If you find them, please report them .. nothing looks more ugly than
> typos in the original language ..
> Thanks to Carlos Davila I just fixed some typos in the source code..
> I do not assume that it will go up to hundreds but
> 1. try to keep up with the latest strings if you can
> 2. report any typo that you find during your work
> 3. you can request a string language update for your language
> everytime if you are not able to do it by yourself .. just drop me a
> note with the language code of your language ..
> As soon as we are getting closer to the release date (at least one
> week before release) I will update all languages again for a last time
> to bring in the few typos that might have changed during the fixing
> period.
> For you it should then just be a matter of clicking OK in Linguist to
> accept what has already been there (or correct if you "mis"translated
> the typo.
> Thanks a lot for all your work .. QGIS 2.0 looks already great .. You
> will love the new features!
> kind regards
> Werner
> Qgis-tr mailing list
> Qgis-tr at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-tr
More information about the Qgis-tr mailing list
