[Qgis-tr] [Qgis-community-team] latex/pdf guru's for failing Korean and Hindi pdf build available?
Ko Nagase nagase at georepublic.co.jp
Wed Jun 18 05:16:32 PDT 2014
Hi Richard, BJ Jang
Thanks for confirmation.
I just pushed yesterday code to my git repository "xelatex" branch.
branch root: https://github.com/sanak/QGIS-Documentation/tree/xelatex
commit diff: https://github.com/sanak/QGIS-Documentation/commit/e9a02494547c5b8f7ed4581c57ee492cd9b4ecff
I confirmed Ubuntu 12.04 (precise = Debian Squeeze) xeCJK package is
too old (Version 2.3.10 (30-Sept-2009)),
and that seems to be the cause of Korean space issue.
It may also be possible to build xeCJK source by hand,
but I am not so familiar with LaTeX .etc...
Is there some plan about upgrading current documentation server to
Debian Wheezy?
Anyway, I will try to create Debian Squeeze/Wheezy environment from
scratch by Vagrant,
and check it again in this weekend, because now I am testing only on
Ubuntu 12.04 (precise).
Thanks,
2014-06-18 20:21 GMT+09:00 Richard Duivenvoorde <richard at duif.net>:
> On 17-06-14 14:50, Ko Nagase wrote:
>> So, please check that your current "source/i18n/ko/conf.py" includes
>> both original "source/conf.py"
>> and extra "source/i18n/ko/conf.py.diff" contents.
> Thanks for the hints.
> I added this piece of config in the normal source.conf file, but do not
> get better results then the other pdf without.
> It is not clear to me if this is because of my own setup (missing
> essential korean fonts or packages) or if I'm doing something else wrong.
> BJ Jang: are you able to build the Korean pdf yourself?
> Any help is appreciated
> Regards,
Ko Nagase (長瀬 興)
Georepublic Japan
mail: nagase at georepublic.co.jp
web: http://georepublic.co.jp
More information about the Qgis-tr mailing list
