[Qgis-tr] [Qgis-community-team] latex/pdf guru's for failing Korean and Hindi pdf build available?
Ko Nagase nagase at georepublic.co.jp
Wed Jun 18 05:45:08 PDT 2014
Hi Richard,
Thanks for your response.
2014-06-18 21:27 GMT+09:00 Richard Duivenvoorde <richard at duif.net>:
> myself I tested on my Debian jessie/testing laptop here.
> the machine used for building is a Docker image based on wheezy.
Okay.
(I missed Docker settings on the code root...)
> I'll try there and see how it looks.
Okay, thanks!
Regards,
> On 18-06-14 14:16, Ko Nagase wrote:
>> Hi Richard, BJ Jang
>> Thanks for confirmation.
>> I just pushed yesterday code to my git repository "xelatex" branch.
>> branch root: https://github.com/sanak/QGIS-Documentation/tree/xelatex
>> commit diff: https://github.com/sanak/QGIS-Documentation/commit/e9a02494547c5b8f7ed4581c57ee492cd9b4ecff
>> I confirmed Ubuntu 12.04 (precise = Debian Squeeze) xeCJK package is
>> too old (Version 2.3.10 (30-Sept-2009)),
>> and that seems to be the cause of Korean space issue.
>> It may also be possible to build xeCJK source by hand,
>> but I am not so familiar with LaTeX .etc...
>> Is there some plan about upgrading current documentation server to
>> Debian Wheezy?
>> Anyway, I will try to create Debian Squeeze/Wheezy environment from
>> scratch by Vagrant,
>> and check it again in this weekend, because now I am testing only on
>> Ubuntu 12.04 (precise).
>> Thanks,
>> 2014-06-18 20:21 GMT+09:00 Richard Duivenvoorde <richard at duif.net>:
>>> On 17-06-14 14:50, Ko Nagase wrote:
>>>> So, please check that your current "source/i18n/ko/conf.py" includes
>>>> both original "source/conf.py"
>>>> and extra "source/i18n/ko/conf.py.diff" contents.
>>> Thanks for the hints.
>>> I added this piece of config in the normal source.conf file, but do not
>>> get better results then the other pdf without.
>>> It is not clear to me if this is because of my own setup (missing
>>> essential korean fonts or packages) or if I'm doing something else wrong.
>>> BJ Jang: are you able to build the Korean pdf yourself?
>>> Any help is appreciated
>>> Regards,
Ko Nagase (長瀬 興)
Georepublic Japan
mail: nagase at georepublic.co.jp
web: http://georepublic.co.jp
More information about the Qgis-tr mailing list
