[Qgis-tr] [Qgis-community-team] latex/pdf guru's for failing Korean and Hindi pdf build available?
BJ Jang qgis.tr.kr at gmail.com
Sat Jun 21 00:09:00 PDT 2014
Dear Ko
Thank you so much!!!
We got a perfect Korean pdf translation.
All about formatting(Font, spacing, images) is good!
Thank you again Ko.
Regards
BJ Jang
2014-06-20 21:23 GMT+09:00 Ko Nagase <nagase at georepublic.co.jp>:
> Hi BJ Jang, Hindi translator, Richard
> > BJ Jang
> I fixed Korean space issue by using Debian Wheezy newer xeCJK module,
> and applying the following link way.
> 2014-06-17 21:32 GMT+09:00 Ko Nagase <nagase at georepublic.co.jp>:
> > [1]
> http://tex.stackexchange.com/questions/17292/how-to-write-spaces-between-korean-words-with-xecjk/
> So, could you check the following new PDF again?
> Korean PDF:
> https://dl.dropboxusercontent.com/u/93823511/QGIS-testing-UserGuide-ko-wheezy.pdf
> > Hindi translator
> I added Hindi version PDF here.
> Hindi PDF:
> https://dl.dropboxusercontent.com/u/93823511/QGIS-testing-UserGuide-hi-wheezy.pdf
> I hope that someone check this one.
> > Richard
> I updated my "xelatex" branch to fix Korean space issue and add Hindi
> extra settings.
> If above files are valid ones, I will create pull request.
> == [xelatex] ==
> branch root: https://github.com/sanak/QGIS-Documentation/tree/xelatex
> I also created "vagrant" branch to use Debian Wheezy 7.5 x64 image on
> my MacOSX note PC.
> About package lists for the image, please see the following "bootstrap.sh".
> == [vagrant] ==
> branch root: https://github.com/sanak/QGIS-Documentation/tree/vagrant
> bootstrap.sh:
> https://github.com/sanak/QGIS-Documentation/blob/vagrant/vagrant/wheezy64/bootstrap.sh
> I wrote that I will try also Debian Squeeze environement in this weekend,
> but I become busy with other tasks, so I set this status to pending for a
> while.
> Regards,
> Ko
> 2014-06-18 21:16 GMT+09:00 Ko Nagase <nagase at georepublic.co.jp>:
> > Hi Richard, BJ Jang
> > Thanks for confirmation.
> > I just pushed yesterday code to my git repository "xelatex" branch.
> > commit diff:
> https://github.com/sanak/QGIS-Documentation/commit/e9a02494547c5b8f7ed4581c57ee492cd9b4ecff
> > I confirmed Ubuntu 12.04 (precise = Debian Squeeze) xeCJK package is
> > too old (Version 2.3.10 (30-Sept-2009)),
> > and that seems to be the cause of Korean space issue.
> > It may also be possible to build xeCJK source by hand,
> > but I am not so familiar with LaTeX .etc...
> > Is there some plan about upgrading current documentation server to
> > Debian Wheezy?
> > Anyway, I will try to create Debian Squeeze/Wheezy environment from
> > scratch by Vagrant,
> > and check it again in this weekend, because now I am testing only on
> > Ubuntu 12.04 (precise).
> > Thanks,
> > 2014-06-18 20:21 GMT+09:00 Richard Duivenvoorde <richard at duif.net>:
> >> On 17-06-14 14:50, Ko Nagase wrote:
> >>> So, please check that your current "source/i18n/ko/conf.py" includes
> >>> both original "source/conf.py"
> >>> and extra "source/i18n/ko/conf.py.diff" contents.
> >> Thanks for the hints.
> >> I added this piece of config in the normal source.conf file, but do not
> >> get better results then the other pdf without.
> >> It is not clear to me if this is because of my own setup (missing
> >> essential korean fonts or packages) or if I'm doing something else
> wrong.
> >> BJ Jang: are you able to build the Korean pdf yourself?
> >> Any help is appreciated
> >> Regards,
> > Ko Nagase (長瀬 興)
> > Georepublic Japan
> > mail: nagase at georepublic.co.jp
> > web: http://georepublic.co.jp
> Ko Nagase (長瀬 興)
> Georepublic Japan
Open Source GIS Technical Manager / e-Cartographer
BJ Jang
*Gaia3D Inc,*
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20140621/986e74f0/attachment.html>
More information about the Qgis-tr mailing list
