[Qgis-tr] Translations
Werner Macho werner.macho at gmail.com
Fri May 23 07:11:12 PDT 2014
Hi Alexandre!
Thanks for the hint - I changed it - and it will be completely deleted
once everything really works fine and is migrated to QGIS umbrella!
regards
Werner
On Fri, May 23, 2014 at 4:06 PM, Alexandre Neto <senhor.neto at gmail.com> wrote:
> Hello werner,
> thank you for the clarification.
> Can you please take the phrase:
> THIS PROJECT IS ONLY FOR TESTING. PLEASE DO NOT USE IT FOR REAL TRANSLATIONS
> YET!
> It will scare new translators away. :)
> Thanks,
> Alexandre Neto
> On Fri, May 23, 2014 at 3:00 PM, Werner Macho <werner.macho at gmail.com>
> wrote:
>> Hi Translators!
>> As there were some questions about using github OR transifex ..
>> Some points:
>> * You can use either github/linguist OR transifex
>> * I still assume that languages with NO entry in [0] use github
>> * For now everything with transifex seems to work - so I will still
>> wait for this release until handing over the project under the QGIS
>> umbrella (just to still have the possibility to take it back)
>> * Only the languages marked with transifex inside the Document from
>> [0] will be pushed into QGIS sources from transifex.
>> * transifex still has the disadvantage of not showing the GUI environment
>> * you can still download the ts file from transifex too and use
>> linguist to translate but be aware that you might be in a team and
>> others would like to colaborate too, so upload it as soon as you are
>> finished with your work
>> Any further question please drop me a mail
>> kind regards and many thanks
>> Werner
>> [0]
>> https://docs.google.com/spreadsheets/d/1PSliZJUR_i07Rqev2iDvTroJMYIyPIKW2EUyhX_pRLw/edit?usp=sharing
>> Qgis-tr mailing list
>> Qgis-tr at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-tr
More information about the Qgis-tr mailing list
