[Qgis-tr] Translation update
João Gaspar joao.f.r.gaspar at gmail.com
Sun Oct 5 12:02:23 PDT 2014
Hi Werner,
in transifex QGIS Website, site_forusers_visualchangelog220,
nodetool is with trim or with a space?
Context string is:
``Delete`` or ``Backspace`` - delete the selected features (you can undo these
actions), or a node when using the nodetool.
Regards
João
2014-10-05 9:12 GMT+01:00 Werner Macho <werner.macho at gmail.com>:
> Thanks for the hint ..
> Should be changed in current update!
> regards
> Werner
> On Sat, Oct 4, 2014 at 11:58 PM, Junior Delaz <delazj at gmail.com> wrote:
> > Hi all,
> > I think this text should also be fixed (still in QGIS Desktop):
> > - Layers do not all use the same CRS. This can cause unexpected results.
> Do
> > you want tocontinue? (n°1234)
> > 2014-10-04 13:12 GMT+02:00 Alexander Bruy <alexander.bruy at gmail.com>:
> >> Typos fixed. BTW one was not in Processing, but in DXF export dialog
> >> 2014-10-04 13:40 GMT+03:00 João Gaspar <joao.f.r.gaspar at gmail.com>:
> >> > Ok. :) For now 100% qgis-application PT translated.
> >> > I'm in stand by for future changes.
> >> > Regards
> >> > 2014-10-04 11:35 GMT+01:00 Alexander Bruy <alexander.bruy at gmail.com>:
> >> >> Hi João,
> >> >> 2014-10-04 13:14 GMT+03:00 João Gaspar <joao.f.r.gaspar at gmail.com>:
> >> >> > All files(*.*);;
> >> >> This is correct string, it is a part of file dialog filter string
> >> >> Regarding all other bugs, I'll try to fix them ASAP.
> >> >> Alexander Bruy
> >> >> _______________________________________________
> >> >> Qgis-tr mailing list
> >> >> Qgis-tr at lists.osgeo.org
> >> >> http://lists.osgeo.org/mailman/listinfo/qgis-tr
> >> Alexander Bruy
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20141005/5e2a58f3/attachment.html>
More information about the Qgis-tr mailing list
