[Qgis-tr] [Qgis-developer] size of translations, use a distinct repo?
Werner Macho werner.macho at gmail.com
Wed Oct 29 06:06:23 PDT 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Good idea,
if its really translation that causes the growth we should do
everything to avoid that.
Is there any way to "shrink" the already existing repo?
At one point I thought about zipping the ts files - but if there is a
better way .. good!
I always wondered why the whole translations file has to be changed
whenever there are only some small changes ..
moving the translation in it's own github repository: hmm - I don't
know if thats easily possible.. but I am also willing to try it if it
helps the source code to stay clean.
But again - anyway to shrink the already existing source code?
I don't mind about loosing track of translation changes.
regards
Werner
On 10/29/2014 12:15 PM, Jürgen E. Fischer wrote:
> Hi Denis,
> On Wed, 29. Oct 2014 at 11:08:16 +0100, Denis Rouzaud wrote:
>> Any thoughts?
> I guess this is just due to the "location filename" stuff.  That
> often causes massive change in the ts files, because lines were
> added or removed from the source files - even if there isn't even a
> changed translation.
> I think that is not used at all for transifex and it's not that
> important to have in linguist either.
> So instead of inventing something new, all it takes might be to add
> "-locations none" to our lupdate call, reduce the size of the .ts
> files a lot (in one huge commit) and avoid useless tracking of
> location changes in the future.
> Objections?
> Jürgen
> _______________________________________________ Qgis-tr mailing
> list Qgis-tr at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-tr
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.15 (GNU/Linux)
iEYEARECAAYFAlRQ5k8ACgkQDAH1YiCxBgn7TQCeKllHCgzKm1Jn2iRT6iwPXkPd
qmsAnjjWeXZySoZX9WQYf82w4s64s2ql
=AGCZ
-----END PGP SIGNATURE-----
More information about the Qgis-tr mailing list
