[Qgis-tr] Missing images for the Romanian language
Richard Duivenvoorde rdmailings at duif.net
Sat Jul 23 13:50:47 PDT 2016
> Unfortunately, the page
> http://www2.qgis.org/ro/site/forusers/visualchangelog216/index.html does
> not show a lot of pictures.
> Looking closer I've found out that all links are correct, but the images
> were not copied in the RO directory (http://www2.qgis.org/ro/_images/) -
> it contains only 551 image files while the original English one
> (http://www2.qgis.org/en/_images/) contains 621.
> I'd like to know how to fix this issue.
Hi Sorin,
not sure, but I tried to run the build by hand and it stopped with:
Warning, treated as error:
/site/source/site/getinvolved/development/bugreporting.rst:21: WARNING:
undefined label: listele de discu\u021bii qgis (if the link has no
caption the label must precede
 a section header)
And another one in a page about sponsoring...
what I think is that because there is a half build website, also half of
images are copied.. or so?
are you able to fix the translation yourself, or in other words: are you
able to run a full build (including the pulling from transifex)
yourself? It looks like a 'label' is translated (which should not).
I looked and two times a label is translated ( by you ;-) ):
 :ref:`QGIS-sponsoring`
in a sentence, for example was translated to:
 :ref:`Sponsorizărilor-QGIS`
BUT this :ref: thingies are just 'anchors' in a page so should NOT be
translated!
Anyway, fixed and rebuild
Regards,
Richard
More information about the Qgis-tr mailing list
