[Qgis-tr] Typo in qgis-application .ts-file
Werner Macho werner.macho at gmail.com
Fri Nov 11 09:37:38 PST 2016
Sorry for coming back on this such late but I was on the road..
Yes it is a matter of yource - and the patch is already accepted -
thanks for that.
translations sources should be updated automatically ..
Now we could also think about backporting it to 2.14 and 2.18 - but on
the other hand - translation is always concentrating on master ..
kind regards
Werner
On 11/11/16 18:16, DelazJ wrote:
> Transifex Webtranslation page for QGIS is on https://www.transifex.com/qgis/
> Yes,
> You're right, I read again your first message and it's not a matter of
> translation but of source code indeed. I proposed a fix at
> https://github.com/qgis/QGIS/pull/3753 so no need to report a bug, yet.
> Thanks for your report.
> 2016-11-11 17:29 GMT+01:00 Sveinn í Felli <sv1 at fellsnet.is
> <mailto:sv1 at fellsnet.is>>:
>     https://www.transifex.com/qgis/ <https://www.transifex.com/qgis/>
>     Thanks a lot;
>     Þann fös 11.nóv 2016 11:13, skrifaði DelazJ:
>         Hi,
>         2016-11-10 9:09 GMT+01:00 Sveinn í Felli <sv1 at fellsnet.is
>             Hi,
>             I'm new on this list, so excuse me if there is another
>             procedure for
>             reporting source text errors. But first:
>             In my qgis-application_is.ts file there is the message
>             "Barscale Options"
>             in between other messages about "Scalebar" (approx. line #
>             28845):
>                 <message>
>                     <source>Scalebar segment size mode</source>
>                     <translation type="unfinished"></translation>
>                 </message>
>             </context>
>             <context>
>                 <name>QgsComposerScaleBarWidgetBase</name>
>                 <message>
>                     <source>Barscale Options</source>
>                     <translation>Valkostir kvarðastiku</translation>
>                 </message>
>                 <message>
>                     <source>Scalebar</source>
>             Is this an error ?
>             Should "barscale" be "scalebar" ?
>     Investigating a bit the other translations (es, fr, de) on GitHub,
>     it seems that most translators treat "barscale" the same as
>     "scalebar". So I'll do the same.
>     Nevertheless, to me such discrepancies seem like a bug, which I will
>     report in the bugtracker (hopefully soon).
>             I've seen some other errors and imprecisions in the source
>             text, apart
>             from reporting a bug, is there another way to
>             announce/submit potential
>             typos (for discussion first, then maybe submit a bug) ?
>             Yes, there are other ways to get things fixed:
>         - You can report it here or at hub.qgis.org
>         <http://hub.qgis.org> (tagged as translation) and
>         hope someone will do the job (note that as you began, it can be an
>         opportunity to discuss things but I'm not sure it's the
>         best/quickest way)
>     Thanks, I think
>     <http://hub.qgis.org/projects/quantum-gis/issues?set_filter=1&tracker_id=1
>     <http://hub.qgis.org/projects/quantum-gis/issues?set_filter=1&tracker_id=1>>
>     will be a good point of entry.
>         - Given that you have access to qgis-application_is.ts file I
>         assume you
>         already have an account on Transifex (otherwise, see
>         http://qgis.org/en/site/getinvolved/translate.html#becoming-a-translator
>         <http://qgis.org/en/site/getinvolved/translate.html#becoming-a-translator>).
>         You can directly fix strings from the web interface or download
>         the file
>         and fix it locally before pushing it to web (some notes about
>         this process
>         at
>         http://docs.qgis.org/2.14/en/docs/documentation_guidelines/do_translations.html
>         <http://docs.qgis.org/2.14/en/docs/documentation_guidelines/do_translations.html>
>         though a bit documentation oriented). Note that those fixes in
>         qgis-application_is.ts file will apply to QGIS3.0 as it's the
>         next release.
>         The Transifex webpage also offered a chat room which imho seems
>         a better
>         place to discuss icelandic translation stuffs
>     This is about the source code, not specifically Icelandic.
>         - If you want strings to be fixed in earlier maintained releases
>         (actually
>         2.14 and 2.18), you need to propose a pull request to the branch
>         in QGIS
>         repository (www.github.com/qgis/QGIS
>         <http://www.github.com/qgis/QGIS>). You'll need a github
>         account, fork
>         the QGIS repository and fixes a qgis_is.ts which should, if i'm
>         not wrong,
>         be in https://github.com/qgis/QGIS/tree/release-2_18/i18n
>         <https://github.com/qgis/QGIS/tree/release-2_18/i18n> (i
>         couldn't find
>         it, unless Icelandic has another code than "is").
>     This is really interesting, thanks again.
>     Or is it because they not
>         yet reach the minimum required to be pushed to desktop
>         application (they
>         are at 50%)?
>     Well, we are at 50% since yesterday when I pushed my last changes.
>     That is 50% of the number of strings, counting words it's nearer to
>     25% ;-(
>     There used to be a release for Icelandic some years ago (before
>     transifex?), you can get still that from conservative repositories
>     like Ubuntu which has QGIS v.2.0.1
>     But for QGIS v.2.18 and in the git.repo, Icelandic is absent.
>     I have to roll my own qgis_is.qm and drop it to the i18n-directory
>     to test my translations, works really well.
>     The primary interface and menus are done, secondary dialogs and most
>     configuration options are well advanced; expert options and popups
>     are ahead.
>         Hope that clarifies things and if it doesn't, please ask again,
>         Harrissou
>     Thanks a lot,
>     Sveinn í Felli
>         Best regards,
>             Sveinn í Felli
>             _______________________________________________
>             QGIS-Translators mailing list
>             Qgis-tr at lists.osgeo.org <mailto:Qgis-tr at lists.osgeo.org>
>             http://lists.osgeo.org/mailman/listinfo/qgis-tr
>             <http://lists.osgeo.org/mailman/listinfo/qgis-tr>
More information about the Qgis-tr mailing list
