[Qgis-tr] some questions
Stefano Campus skampus at gmail.com
Tue Oct 3 15:52:06 PDT 2017
thank you all for replies.
my organization will adopt the 2.18 version as soon as it becomes LTR and
will hold it for at least a year.
Do you think it is correct to use the current version of transifex file.ts,
transform it into the corresponding .qm version, through qt linguist, and
use it as the italian version of version 2.18 LTR?
I know there are so many more strings than master version but I think that
strings that are not present in 2.18 are not a problem.
Am I right?
thank you again
stefano
2017-10-01 11:01 GMT+02:00 Richard Duivenvoorde <rdmailings at duif.net>:
> On 01-10-17 00:33, Jürgen E. Fischer wrote:
> >> 3) Is there any chance of using the .ts file that you can download from
> >> transifex in qgis and see "live" the results of our translation?
> transifex
> >> is very powerful but sometimes is very difficult to translate withow the
> >> knowledge of context.
> > The nightlies of master pull them in on every build.  But you can also
> download
> > the .ts file for use or translation.
> If I am correct, you should be able to:
> - download the .ts file from Transifex.com
> - use Qt-Linguist to do further translations
> - use command line OR Qt-Linguist to 'compile/release' your .ts file to
> a .qm file
> - if you put THAT .qm file on the right place in your QGIS installation,
> QGIS will show you your fresh translations
> - do not forget to copy your translations back to transifex, uploading
> is also an option, but you will override any translations done while you
> downloaded your sources.
> HTH
> Regards,
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20171004/27765459/attachment.html>
More information about the Qgis-tr mailing list
