[Qgis-tr] Updating my desktop app with new translations
Ari Jolma ari.jolma at gmail.com
Tue Feb 20 01:01:07 PST 2018
On 20.02.2018 10:18, Jürgen E. Fischer wrote:
>> How do I update my QGIS desktop app with the latest translation?
> scripts/pull_ts.sh
> Our nightlies also do this.
Thanks.
That required me to update my urllib3 using pip (the one from Linux Mint
18.1 was not new enough) and install XML::Simple (perl module). I also
had to create ~/.transifexrc file like this
[https://www.transifex.com]
api_hostname = https://api.transifex.com
hostname = https://www.transifex.com
password = password
token =
username = ajolma
(the "token =" is necessary). I also had to set the transifex password
since github login is not ok for using the API.
The pull_ts.sh is *very* slow since it seems to delete all ts-files and
not do an update (although it says "New translations found...").
Probably the best way is to somehow download only my (finnish) ts-file
using the transfix API and use Qt4 Linguist and then install the qm file.
Ari
>> I do translations in transifex and use the QGIS from github master. However,
>> the i18n files (*.ts) in github are quite old.
> They are only updated on release.
> Jürgen
> QGIS-Translators mailing list
> Qgis-tr at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-tr
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20180220/a1339e92/attachment.html>
More information about the Qgis-tr mailing list
