[Qgis-tr] Available resources
Leônidas Descovi Filho leonprs at gmail.com
Thu Apr 23 07:27:10 PDT 2020
Não está bloqueando. A vesão atual pode ser finalizada.
São tarefas não finalizadas que não permitirão que as equipes concluam 100%
das traduções do qgis desktop no transifex.
Rgs
Leônidas
Em qui., 23 de abr. de 2020 às 11:18, Werner Macho <werner.macho at gmail.com>
escreveu:
> Transifex Webtranslation page for QGIS is on
> https://www.transifex.com/qgis/
> Hi!
> As long as (in the longer term) QGIS will get no release update for that
> versions it makes no sense to unlock them.
> We might as well get rid of them, but I assume (still not sure though)
> that we'll loose the suggestions for new translations if we remove them.
> Are the translations in any way blocking the continuous translation of
> master or current LTR release?
> regards
> Werner
> On Thu, Apr 23, 2020 at 4:01 PM Leônidas Descovi Filho <leonprs at gmail.com>
>> Hi Richard
>> Is the goal of the teams to zero the translations?
>> If so, in my opinion it either opens up to translate them or withdraws.
>> It does not make sense to just be them as pending there in the transifex.
>> Regards
>> Leônidas
>> Em qui., 23 de abr. de 2020 às 10:49, Richard Duivenvoorde <
>> rdmailings at duif.net> escreveu:
>>> Hi Leônidas,
>>> Sorry for my ignorance, but would you still translate 3.4 or 3.8? As
>>> these are older non-LTR versions.
>>> Is it a problem they are 'locked'?
>>> Regards,
>>> > Hi
>>> > I have a similar problem in the qgis desktop pt_Br.
>>> > I request unlocking or removing release-3-4 - qgis-application and
>>> > release-3-8 - qgis-application.
>>> > Thank you.
>>> > Best Regards.
>>> > Leônidas
>>> > Em qua., 22 de abr. de 2020 às 19:58, Stefano Campus <
>>> skampus at gmail.com
>>> > <mailto:skampus at gmail.com>> escreveu:
>>> >     ciao,
>>> >     sorry if I re-propose the theme.
>>> >     is it possible to remove from transifex the set of strings to be
>>> >     translated from the old versions of qgis?
>>> >     We have Resource that are not editable from:
>>> >     thank you in advance for your reply
>>> >     s.
>>> >     _______________________________________________
>>> >     QGIS-Translators mailing list
>>> >     Qgis-tr at lists.osgeo.org <mailto:Qgis-tr at lists.osgeo.org>
>>> >     https://lists.osgeo.org/mailman/listinfo/qgis-tr
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20200423/02c378e8/attachment.html>
More information about the Qgis-tr mailing list
