[Qgis-tr] Publication of the translation of the strings and documentation
Richard Duivenvoorde rdmailings at duif.net
Sat Jul 18 13:02:51 PDT 2020
Hi Stefano,
Just pulled all translations from transifex and pushed to github:
https://github.com/qgis/QGIS-Documentation/commit/69b7efbba1295b375b0421c1fcc6d17888afc432
With this fresh translations in github, it should be pretty easy now to build current version.
Please try:
https://github.com/qgis/QGIS-Documentation/tree/release_3.10#building-the-documentation
And let us know if you have troubles
Regards,
On 7/18/20 2:23 PM, Richard Duivenvoorde wrote:
> Transifex Webtranslation page for QGIS is on https://www.transifex.com/qgis/
>> ciao
>> in the last few days, the Italian community of translators has accelerated the activity and we hope to get 100% translation of the GUI for LTR, stable and dev versions and of the documentation.
>> however, we noticed that some strings that are translated and validated do not appear in the new versions; does the publication procedure of the new versions plan to "take" from Transifex every time or does this happen every now and then?
>> The translation part of the web manual is also not synchronized with Transifex.
>> I also wanted to ask how to update the part of the credits to translators found in the GUI, under the Help menu.
>> thank you so much
>> s.
> Hi Stefano,
> We/I did not yet automate the new Docs setup. So pulling transifex sources (and putting it in github) is done by hand every now and then.. Look at
> https://github.com/qgis/QGIS-Documentation/tree/release_3.10/locale
> apparently 10 days ago
> I will do it now, and then build. But it takes about 20 minutes per language to pull over... so it takes some time.... that is the reason we do not do it every day anymore
> Regards,
> QGIS-Translators mailing list
> Qgis-tr at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-tr
More information about the Qgis-tr mailing list
