[QGIS-trac] Re: [Quantum GIS] #1166: WMS / WFS not valid SRS requests
Quantum GIS qgis at qgis.org
Sat Aug 2 04:16:25 EDT 2008
        Reporter:  LuizDomingues53                   |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.0
       Component:  WMS                               |       Version:  0.11.0
      Resolution:                                    |      Keywords:  WMS WFS
Platform_version:                                    |      Platform:  Windows
        Must_fix:  No                                |   Status_info:  1
Changes (by timlinux):
  * priority:  critical: causes crash or data corruption => major: does not
               work as expected
  * status_info:  0 => 1
  * must_fix:  Yes => No
Comment:
 Hi
 Could you give a public server url to test against? Its not possibly to
 test using the url you provided since the url is on your localhost. Also
 I'm changing the severity of this ticket to major as it doesnt seem to
 actually be causing a crash or any data corruption. Also the epsg file we
 use is the one maintained for gdal & proj, which should be the basis of
 the one used for mapserver too. The qgis EGSG database was updated prior
 to release of 0.11.0 'Metis' to be in sync with current proj4 / gdal epsg
 database. I'm marking this ticket 'pending user feedback' and will close
 it in a few weeks if no feedback has been received.
 I see that its trying to use : SRS=CRS:84
 What is the expected EPSG? Also 84?
 Are you using 'on the fly' projection?
 The more detail you can give me the better.
 Muito obrigado!
 Tim
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1166#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
