[QGIS-trac] [Quantum GIS] #1209: GPS plugin - use stored path for all file browser dialogs; also save/use file type
Quantum GIS qgis at qgis.org
Wed Aug 6 21:05:46 EDT 2008
file type
   Reporter:  smizuno                          |              Owner:  nobody
       Type:  enhancement                      |             Status:  new
   Priority:  minor: annoyance or enhancement  |          Milestone:  Version 1.0.0
  Component:  Plugins                          |            Version:  HEAD
   Keywords:                                   |   Platform_version:
   Platform:  All                              |           Must_fix:  No
Status_info:  0                                |
 1. GPS Tools (GPS Importer) - use stored path to GPX file to initialize
 the file dialog (and save on successful operation) in the following
 tools/file browsing:
 Import other file - "GPX output" field
 Download from GPS - "Output file" field
 GPX conversions - "GPX output file" field
 as is done for Load GPX file (File) and GPX conversions (GPX input file)
 Also do this for Create new GPX layer.
 I reason that most users will probably be storing GPX files in the same
 general location, perhaps one directory up/down from there, plus it is
 very annoying to have to navigate from current working directory every
 time the file browse dialog is used.
 2. use a different stored path to initialize the file dialog (and save on
 successful operation) in the Import other file - "File to import" field
 Same reasons as in item 1, except that this is a different type of file
 that may be stored in a different location.
 3. store the type of file and initialize the file dialog from this for
 "File to import" in the Import other file tool.
 Reason is that a user is likely to be importing a number of files of the
 same type, so it is annoying to have to set the type each time.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1209>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
