[QGIS-trac] Re: [Quantum GIS] #1221: layer with non-standard CRS doesn't get its CRS set correctly on loading file or project
Quantum GIS qgis at qgis.org
Mon Aug 18 12:08:40 EDT 2008
file or project
        Reporter:  smizuno                           |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.0
       Component:  Projection Support                |       Version:  HEAD
      Resolution:                                    |      Keywords:  layer projection loading
Platform_version:                                    |      Platform:  Windows
        Must_fix:  No                                |   Status_info:  0
Comment (by cgsbob):
 I am running r9060 on a Ubuntu 8.04 X86_64 system with qt4.4 and I'm
 having the same problem.  I mentioned this problem in IRC a few days ago
 and this is what I wrote:
 <CGI617> Now I have another weird problem.  I load a latlon nad27 quad map
 of California and a geology map in state plane zone 3 nad27 with otf
 turned on.  Saved it in a project and reran qgis.
 <CGI617> otf is still on and each layer pointing to the right projection,
 but the layers don't over lay each other.  Looking at the metadata of the
 geology layer shows that the projection has changed.  In the proj string
 x_0=2000000 instead of 609601.2192024384.
 <CGI617> I click on the layer properties general tab and click on Change
 CRS and I can see that the right projection is selected.  After clicking
 on OK and then OK on the layer properties dialog box, I can see the
 geology feature move to the correct position.
 <CGI617> it seems that qgis assumes that the projection used meters
 instead of feet.
 Replying to [ticket:1221 smizuno]:
 > The situation:
 > 1. project CRS set to epsg:26915 with on-the-fly projection enabled; a
 layer in epsg:26915 for reference.
 > 2. A shape file in Washington county coordinates, feet (Minnesota) with
 a .prj file.
 > 3. a custom CRS defining the Washington county coordinates is defined.
 > Steps to show the problems:
 > 1. Add Vector Layer - choose the shape file noted above.
 > 2. the dialog to set the layer CRS appears - choose the custom CRS noted
 above.
 > 3. the layer is added, but is not projected in the proper location.
 > 4. check the Layer Properties, General or Metadata tab - the CRS listed
 is WGS84 parameters (depends on QGIS settings).
 > 5. on the General tab of Layer Properties change the CRS to the custom
 CRS noted above.
 > 6. now the layer projects in the proper location.
 > 7. save the project
 > 8. load the project
 > 9. the layer is projected in the wrong location.
 > 10. check the CRS in layer properties - it is wrong.
 > 11. set the custom CRS for the layer.
 > 12. now the layer is projected correctly.
 > There are three problems here:
 > First, the .prj file wasn't used like it is in some previous versions of
 QGIS. 0.9.1 used the .prj file; 0.10.0 doesn't, but at least set the CRS
 from the dialog.
 > Second, the CRS set via the dialog presented on layer loading isn't
 saved.
 > Third, a project containing a Washington county coordinates layer is
 loaded incorrectly.
 > Some details about loading the saved project: after loading, the CRS is
 not correct - the x_0 and y_0 values are wrong (they are the epsg:26915
 coordinates of the lat_0, lon_0 parameters in the Washington county
 coordinates CRS)
 > The project file has the correct values.
 > the custom CRS:
 > {{{+proj=tmerc +lat_0=44.74583333333334 +lon_0=-92.83333333333331
 +k=1.000040 +x_0=152406.3759 +y_0=30481.27509999999 +ellps=GRS80
 +datum=NAD83 +to_meter=0.3048006096012192 +no_defs}}}
 > as loaded from the project file:
 +k=1.00004 +x_0=500019.9182652503 +y_0=100003.9833905833 +ellps=GRS80
 +datum=NAD83 +to_meter=0.3048006096012192 +no_defs }}}
 > my system: Windows XP, GEOS 3.0.0, GDAL 1.5.2, QGIS r9061
 > I haven't tested on Linux yet.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1221#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
