[QGIS-trac] Re: [Quantum GIS] #1147: WMS Layer Scale Problem
Quantum GIS qgis at qgis.org
Fri Dec 5 08:08:02 EST 2008
        Reporter:  morgan                            |         Owner:  nobody
            Type:  defect                            |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.0
       Component:  WMS                               |       Version:  0.10.0
      Resolution:  fixed                             |      Keywords:  WMS scale
Platform_version:                                    |      Platform:  Linux
        Must_fix:  No                                |   Status_info:  0
Changes (by mhugent):
  * status:  new => closed
  * resolution:  => fixed
 I cannot reprocude this problems. The layers from this WMS seem to work
 fine, also the scale seems reasonable (tested with WGS84 and NAD83).
 > QGIS seems to think areas as large as Pennsylvania counties are less
 then 2 inches across
 What kind of tool did you use. The measuring tool? Seems to work fine for
 me. You could check, if the dialog project properties -> general -> map
 units shows decimal degree.
 I'm closing this bug, as it is already 5 months old. Feel free to reopen
 if you still have this problem.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1147#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
