[QGIS-trac] Re: [Quantum GIS] #1128: QGIS 0.10.0 crashes when using print composer
Quantum GIS qgis at qgis.org
Tue Jul 1 13:01:24 EDT 2008
        Reporter:  morgan                                     |         Owner:  nobody
            Type:  defect                                     |        Status:  new
        Priority:  critical: causes crash or data corruption  |     Milestone:
       Component:  Printing                                   |       Version:  0.10.0
      Resolution:                                             |      Keywords:  print composer, ubuntu, kde, kubuntu, print, printing
Platform_version:  Ubuntu 8.04                                |      Platform:  Linux
        Must_fix:  No                                         |   Status_info:  0
Comment (by cuz):
 My issue probably shouldn't be a separate ticket as it ONLY happens in
 print composer. Save as image from the main window works fine. (This is
 not to say that the issue is necessarily the same, only that it should not
 be moved on account of its relation to print composer.)
 The problem also occurred only with some shapefiles even in the absence of
 PostGIS layers.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1128#comment:6>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
